GU Leaking Diesel
Submitted: Thursday, Sep 27, 2007 at 17:11
ThreadID: 50082 Views:1955 Replies:5 FollowUps:1
Have a 2000 GU Patrol 3.0 Ltr T/Diesel. Its leaking fuel from the drivers side from up above the front diff. Cannot find the exact spot for love nor money. Anybody heard of a similar problem and what the source might be??? Cheers
Reply By: Member -Dodger - Thursday, Sep 27, 2007 at 17:14
Have a look at the hoses that connect the fuel filter to the fuel line maybe a small hole in the line.
Cheers Dodg.
AnswerID: 264212
Reply By: obee - Thursday, Sep 27, 2007 at 19:02
which side is the injector pump? I had an old hilux that leaked from the throttle actuator once. It needed an o ring.
owen
AnswerID: 264228
Reply By: Member - Niss42 - Thursday, Sep 27, 2007 at 19:42
Same problem found yesterday , 2000 4.2 TD?????
Barry
AnswerID: 264239
Reply By: Voxson - Friday, Sep 28, 2007 at 12:15
Up around the intercooler on the drivers side.
Take the top cover off and have a look.
AnswerID: 264264
Follow Up By: hl - Friday, Sep 28, 2007 at 13:26
Check the drain tap at the bottom of the fuel filter.
There is also a small o-ring inside (you have to unscrew the whole tap), if that is cracked, it will leak. It would be hard to start too, especially if it has been standing for a few hours.
FollowupID: 526000
Reply By: Wayne's 60 - Friday, Sep 28, 2007 at 17:23
Have you tried looking for the leak with the engine running? May be a pressure leak. Just a thought.
Wayne.
One day they will understand.
AnswerID: 264308
