Site Search
Section Image
2.8 DIESEL 4RUNNER 89 MODEL
Submitted: Monday, Oct 01, 2007 at 18:07
Trace & Paul
We are wanting to do the trip around oz towing a camper trailer. Thing is ,we can't really afford to upgrade our car. We currently have a 2.8 diesel 89 4runner in good running order.
It is pretty much stock standard and we are after ideas of modifications that we will need or should do as well as any input on how to give it a bit more power if possible!
Any comments - good or bad - are most welcome........
Advertisement
ThreadID: 50173 Replies: 3
Views: 478 FollowUps: 1
AnswerID: 264601   Submitted: Monday, Oct 01, 2007 at 19:45
Member - Nick (TAS) replied:
We've done plenty of touring in our old 94 4 Runner 2.8, they are a top vehicle but very underpowered.If you are towing id up grade your suspension.If you dont want to go the turbo mod for more power, Id fit a foam airfilter, extractors,snorkel and a 2 1/2 exhaust.Then give the girl a good service ie all oils,belts,hoses etc.
Then enjoy.
Our Camps - Australian Mainland
Click Image to Enlarge
Our Camps - Mainland Australia
Reply 1 of 3
AnswerID: 264605   Submitted: Monday, Oct 01, 2007 at 20:35
AMack replied:
I have a 2.8 Hilux ute and would dearly love more power BUT I have left mine stock and persevered and reaped the benefits of outstanding reliability and extremely cheap running costs.
1stly ensure you are getting less than 11l/100 otherwise check injectors etc. Invest in a quality fuel filter and change regularly, as well as air filter. Check condition of air pipe between air filter and engine for deterioration and filter chamber as filters can leak dust. If you are staying stock then ensure you run 205/16 or equivalent tyres, 31" or bigger tyres knock off what little grunt these engines have. Tow in 4th unless a tail wind, your gearbox will go forever. If you haven't changed all gear and diff oils do it and you'll probably never have to do it again, unless you've been through water.
Very very tough engine and if the 4runner body is anything like the hilux again very tough and rust resistant.
Reply 2 of 3
AnswerID: 264664   Submitted: Tuesday, Oct 02, 2007 at 08:32
Stiphodon replied:
I used to have an old 2.4D 4runner, one thing that you will find ubiquitous in these older toyotas is that the rear leaf springs will have sagged with age. You will find that once you load up with gear, plus have the camper hitched on the back, you will be sitting fairly ar.se heavy and your rear clearance will be greatly reduced. For a fairly small cost ($300-400) you can get your rear springs re-tensioned and even get an extra leaf fitted if you feel it necessary. This way your wont be grinding your towball on every creek crossing, and you will have much more travel to abosrb the bumps and knocks
Reply 3 of 3
FollowupID: 526587   Submitted: Tuesday, Oct 02, 2007 at 21:58
madfisher posted:
89 used coils on rear which are cheap as chips to replace. $190 for ehd on my old runner.
cheers Pete
