it's hot in here!!
Submitted: Friday, Oct 05, 2007 at 08:15
ThreadID: 50258 Views:3179 Replies:4 FollowUps:3
Hi all
Well, we made it back to the Pilbara, van in tow. It seems though the air con is struggling and it isn't Summer yet! We have lived here before so we know how hot it gets. Air con at present in Dometic on the roof. Just wondering if anyone has any ideas for helping it out. Such as shadecloth - do I just do sides or roof as well - and if so how does air con breathe?? or buy a portable air con which will take up floor space?? We can cope it's the baby who is really making his opinion loud and clear!!
Thanks all
Mal
Reply By: Wizard1 - Friday, Oct 05, 2007 at 08:46
I take it you have a full size van and not a poptop.
We have a poptop and have had rope track attached on all sides of the roof. Just drill holes, run a bead of silicon and poprivet.
We then attach shadecloth and either peg it out or use extendable poles to get shade. We find it effective especially when there are no trees for shade.
The side shade when raised up by poles acts as a car port to keep the car cool as well.
You could possibly pop rivet lengths of rope track to your sides, front and rear.
AnswerID: 265124
Reply By: Member - Doug T (Qld) - Friday, Oct 05, 2007 at 08:55
Mal
I too have a Dometic R/C roof mount, What I noticed is that when in a Caravan Pk that has a lot of residents the power is reduced by the extra demand , same goes for heating too , In the Crystal Brook park in Perth where there are 96% permanents the heater was just luke warm
AnswerID: 265125
Reply By: malboyd34 - Friday, Oct 05, 2007 at 09:12
Interesting about the power in Perth. It could be the same here.
The air con we have now is Dometic model B3200. Van is about 24ft reatreat daydream. I think the weather here is about 37 during the day at the moment.
Thanks for the ideas on attaching the shadecloth. I had no idea how to go about it so that gives me a plan for the weekend.
i see in the air con manual you can install another unit in the hatch space but that could all be messy. Might try a portable air con for the young bloke and the shade cloth.
AnswerID: 265127
Follow Up By: turbopete - Friday, Oct 05, 2007 at 09:28
g'day Malboyd..The Pilbara as I remember it does not havehigh humidity u may find that a good water cooler type a/c will be fine and is better for baby as the air is not dried out,if u go that way get a good bonair or the like not a cheap $2 dollar shop unit Peter
FollowupID: 527018
Follow Up By: turbopete - Friday, Oct 05, 2007 at 09:31
in addition to my previous post the most effective way to cool the inside of the van is to prevent the heat so I always use shadecloth to cover as much of the van as possible peter
FollowupID: 527019
Follow Up By: Member - Rotord - Saturday, Oct 06, 2007 at 09:15
The humidity in the Pilbara gets really bad Dec-Jan when it is also hottest . Shade to help the Dometic sounds good . I did some research on caravan aircons and got the impression that the Dometics were over priced , low performing , and old technology . Roof mounted you dont have any choice , but a rear mounted modern inverter system would run rings a Dometic . The old Pilbara hands used to take their annual hollidays Dec-Jan and the Pilbara tended to close down but nowdays big business and Perth based executives insist on working around the year . The baby and motherare going to have a tough time unless you can sort out good aircon and other relief from the conditions . One method once you are based there would be to look for an employer who provides housing and pays the electricity and water bills . Accomodation on the coast is good , but remember that the sea breeze up there is weak and wont provide relief more than a kilometer or so inland . I have had a wonderful 11 years in the Pilbara and srongly recommend it , but you need your living conditions sorted out in your favour and this will almost certainly reqire help from your employer .
FollowupID: 527192
Reply By: Member - Wim (Qld) - Friday, Oct 05, 2007 at 09:35
malboyd34.
Just find some method of shading the van but not obstructing the condenser on the A/C unit. You will reduce the A/C load dramatically.
Wim
Camper setup
July 2012 - Hay River & Binns track
VKS 737 Mobile 0091
Selcall 0091
AnswerID: 265136
