Video and Wind Noise
Submitted: Saturday, Oct 06, 2007 at 20:34
ThreadID: 50304 Views:3307 Replies:6 FollowUps:1
Hi All
We have just ended a 4 week outback odyssey and we have just watched our video and their is heaps of wind noise on the video.
Just wondering if anyone nose of a way to eliminate the wind noise while taking the video.
Reply By: Stoker - Saturday, Oct 06, 2007 at 21:58
Mal
Had a similar problem to yours while videoing on the Great Ocean Road. It was then as a typical bloke that I decided to read the camera instructions. Mine is a Panasonic DVC and has a awind noise reduction feature. Most cameras are pretty well similar. go to camera functions- then recording set up - then wind cut- and turn to on. Does not entirely delete wind noise but makes it 90% better than not having it turned on. Hope this helps.
AnswerID: 265351
Reply By: Shaker - Saturday, Oct 06, 2007 at 22:41
The best way is with an external microphone with a wind sock/screen.
AnswerID: 265360
Follow Up By: RustyHelen - Saturday, Oct 06, 2007 at 22:51
Agree with Shaker. I have tried everything-- wind cut set up on the camera, cloth over the mic point etc etc and after our last efforts have now gone and purchased an external mike. It pins to our collar just below the chin and as long as you are careful with direction cuts out most if not all wind noise.Now the problem is to remember to turn the thing on....
Other option is just turn the volume down if and when you are editing.
Rusty
FollowupID: 527298
Reply By: Member - Brian (Gold Coast) - Sunday, Oct 07, 2007 at 07:58
We just shoot the video.... and unless there is a particular bit of narration that we want to keep, if the wind noise is too much, we edit out the audio and replace it with music. I guess you could replace the narration while editing if you need to. Music also makes the video more "watchable".
Brian
AnswerID: 265382
Reply By: DIO - Sunday, Oct 07, 2007 at 08:34
You need a decent external microphone with a wind screen cover on it. Quiet as a sleeping baby. Any decent Video retailer should be able to help you out - such as Diamonds.
AnswerID: 265390
Reply By: Alan H (Narangba QLD) - Sunday, Oct 07, 2007 at 09:46
If you want the vision and then add a voice over/music afterwards the simplest trick is to get a plug from Dick Smith and stick it in the extension mic socket and this will switch off the sound recording as it is expecting the sound to come through the plug from a microphone.
Just remove the plug when you want background noise as in engine noise etc. This works fine especially for panning at lookouts where wind is a problem and also stops extraneous sounds from other visitors who might be at the lookout
AnswerID: 265404
Reply By: Mike Harding - Sunday, Oct 07, 2007 at 10:09
I don't know that you'll be able to edit it all out but you should be able to reduce it considerably by doing some digital processing on the audio track - this is a little involved but not beyond the capability of anyone who is familiar with computers (don't need to be an expert) this programme (Audacity) is an excellent freeware sound editor with various filtering and effects capabilities:
Audcaity sound editor
You could also use it to filter the bit where you said "@$#*^!)" at the wrong time :) and to add music or additional commentary etc.
Mike Harding
AnswerID: 265407
