Vehicle Maintenance - Why?
Submitted: Thursday, Oct 11, 2007 at 21:12
Member - Garth J (NSW)
I have a 4by manufactured by an international company.
I have owned the said vehicle since 35000km's. It is a 8/2003 build.
It now has 86,000kms on the clock
The vehicle has been serviced as per the book at 10,000km intervals. By a nationwide retailer service outlet. Not a dealer.
40,000 and 80,000 were change all fluids. Including coolant.
Discovered evidence that the radiator had a leak but no temperature rises or malfunction. Refilled last week and today had a pressure test.
A leak had been discovered and radiator needs a recore because it is corroded...to some extent.
Bad luck or what??
Servicing and diagnosis done by the same company and people!
So what options do I have?
Why bother with Maintenance?
....and I am a person who works in electrical maintenance.
Garth
Reply By: Willem - Thursday, Oct 11, 2007 at 22:02
Nothing is absolute and most things mechanical become obsolete.
Just put your hand in your pocket and pay.........lol
266226
Follow Up By: Pete and Lez - Friday, Oct 12, 2007 at 05:04
Don't know where re coring radiator, or pressure testing cooling system is part of routine scheduled maintenance.
As Willem says, dig deep and cough up.
528306
Follow Up By: Willem - Friday, Oct 12, 2007 at 05:12
You like me Pete....can't sleep?? LOL
528308
Follow Up By: nowimnumberone - Friday, Oct 12, 2007 at 18:25
we pressure test every service
528429
Follow Up By: Pete and Lez - Saturday, Oct 13, 2007 at 05:12
Actually I was at work, Willem.
528502
Reply By: Stu050 - Thursday, Oct 11, 2007 at 22:06
It is machinery....It is allowed to break down occasionally.
266228
Follow Up By: disco driver - Thursday, Oct 11, 2007 at 22:11
And usually at the most inconvenient time or place.
It's called Murphy's law or something
528274
Follow Up By: Member - Garth J (NSW) - Thursday, Oct 11, 2007 at 22:21
Disco,
This is a controlled failure.
I spotted the problem and am getting it fixed before my trip to Tassie next week.
Thereby I have tried to avoid the most inconvenient place or time principle!!
Garth
528279
Follow Up By: Stu050 - Thursday, Oct 11, 2007 at 22:26
O'Leary said that Murphy was an optimist
528283
Follow Up By: Pajman Pete (SA) - Friday, Oct 12, 2007 at 10:36
If you are going to Tassie dont miss
Montezuma Falls or the Spray Tunnel. Both near
Zeehan.
Pete
528341
Reply By: Rock Ape - Thursday, Oct 11, 2007 at 22:15
There you go Garth, you have just done yourself out of a job.
2 things. The coolant that was used was not to standard or incorrect for you cooling system or you may have electrolysis or heaven forbid, they did a flyby and charged you anyway.
Maintanance works if done properly and I am a bit sceptical of the people who did yours, unless it turns out to be electrolysis
Have a good one
The Ape
266231
Reply By: Member - Phil G (SA) - Thursday, Oct 11, 2007 at 22:15
Did your "nationwide retailer service outlet" use the genuine Toyota coolant?
266232
Reply By: Bonz (Vic) - Thursday, Oct 11, 2007 at 22:27
Sounds like Toyota and electrolysis, can be a HUGE problem...start running earth links EVERYWHERE
266234
Follow Up By: Member - Garth J (NSW) - Thursday, Oct 11, 2007 at 22:32
Bonz,
Mate,
Is that an educated guess or what??
How about trying for the national service centre???
LOL!!!
Garth
528285
Follow Up By: Bonz (Vic) - Thursday, Oct 11, 2007 at 22:34
hahahahaha nah...I dont want to show off
528286
Follow Up By: Member - JohnR (Vic)&Moses - Thursday, Oct 11, 2007 at 23:12
Garth, he is just trying to minimise risk. Thats his job. Take him to a power pole and he will pee on it to dissuade termites.
528297
Follow Up By: Member - Mike DID - Friday, Oct 12, 2007 at 07:13
If it's like most modern cars, the radiator will be electrically isolated from the engine/body.
So the only reason for corrosion is -
- poor quality materials in the core
- incorrect coolant used that did not inhibit corrosion correctly.
528321
Reply By: Member - Garth J (NSW) - Thursday, Oct 11, 2007 at 22:28
I'm sure the replacement fluid was to AS... blah blah blah or whatever and suitable for late model vehicles with blah blah blah!
All the vehicles get the same stuff out of the big bulky container.
Just like that oil they put in your vehicle.
And I know oils are not oils!!
If electrolysis then a few more similar vehicles should be surfacing.....
Where's all the 120 series Prado's.............
Garth.
266236
Reply By: goingplatinumcomau - Friday, Oct 12, 2007 at 02:01
Toyota coolant should be red
266249
Reply By: Peter 2 - Friday, Oct 12, 2007 at 06:32
Remember though that most manufacturers these days only build a vehicle to last 5 years, planned obsolescence!
If you actually use it for what it was intended most of the time or heaven forbid actually carry a load in it most of the time then you have probably exceeded the design parameters and it has worn out early!
Yes I am very cynical of the current crop of 4wd's on the market and have been for quite a few years hence my present vehicle which as it is 20 years old is 8 years past its 12 year life expectancy.
266251
Reply By: Navigator 1 (NSW) - Friday, Oct 12, 2007 at 06:50
Garth,
I have a a '92 80 Series and the original, copper core, radiator lasted 10 years. It developed a leak and split down the side seam whilst on rough roads on the Tannami, GRR and Gulf roads. It was replaced with an after market, aluminium core, radiator which only lasted nine months. This one failed on the
Cape York trip but was 'patched up' with a container of white pepper to get us back to
Sydney. The mechanic said the radiator had corroded. This time I bought a copper core radiator and fitted it myself. I now service it myself using a top quality coolant mixed to the specifications on the container.
I say, go with the copper core.
See you at
the Pyrenees. Have a good one in Tasmania.
266253
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Oct 12, 2007 at 11:26
G'day Mate, good to see you are into servicing that
well travelled Cruzer. I thought
Adelaide was the place for poor quality
water, but it seems
Sydney isn't good on that report.
Garth has told me he woin't be able to make
the Pyrenees after all that as he will be going on a trip North to
Ballina.
528354
Reply By: Member - Kiwi Kia - Friday, Oct 12, 2007 at 06:53
Let's get back to basics;
What is the expected 'service' life of a radiator these days? Lets say it is 7 years because that's probably the intended life of the vehicle when manufactured. Some radiators will fail early and some will last much longer. Seems like you have one that has failed at the low end of the statistical bell curve. The manufacturer has decided to use the thinnest lowest cost materials that should last say seven years plus a small margin. Modern radiators are made from plastic and aluminium alloys rather then the copper and brass of 'the good old days'. Factors effecting the life of a radiator would also include how much salt
water it has been exposed to (lake bed or beach). Coolant additives only effect the inside of the radiator not the outside surface. Is it possible that your radiators accelerated corrosion started from the outside? I am often amused by people claiming that corrosion is caused by internal factors (coolant additives)when it is usually the air interface where oxidation takes place the quickest.
It's a bit like battery life, buy cheap and replace is a valid argument these days when the service life of a battery is not much different between brands but the cost difference can be several hundred %.
Ever heard of the 'bathtub effect'. Several electronic component failures are likely to occur early in a devices life then nothing goes wrong for many years before lots of failures start to occur again as the device nears the end of it's service life.
266254
Reply By: Member No 1- Friday, Oct 12, 2007 at 07:32
the nation wide chain wouldnt happen to have a lizard for their logo?
i used the chain who supposedly flushed my old coolant and replaced with new....welll guess what...all they did was drain and top up with different solution......they, the coolants, dont like being mixed
end result was new radiator and heater
266262
Reply By: DIO - Friday, Oct 12, 2007 at 09:53
Radiators are a bit like any other component on a vehicle - they will eventually wear out. I'm not aware of any manufacturer with a life-time gaurantee to cover such failures. Bit like the human body, you can take care of it, avoid nasties like smoking, illicit drugs, alcohol, etc but one day it will decide enough is enough and that's the end. The lights go out. Yeah like you stated - WHY BOTHER WITH MAINTENANCE - guess it helps toward making you feel good about whatever it is you are maintaining in the hope that you will get a few extra years, kays, heart-beats etc.
266273
Reply By: Member - Phil G (SA) - Friday, Oct 12, 2007 at 10:12
Your Prado is only 4 years old. Don't blame the vehicle.
You've had non-genuine coolant which IMO has caused your problem. Thats the risk you take with not using the genuine Toyota stuff.
I have friends who get their Toyotas serviced at the local 4wd
shop. They buy and bring the genuine coolant so the correct stuff gets used.
Read about it here
266276
Reply By: obee - Friday, Oct 12, 2007 at 10:54
Corrosion is result of electrical current between dissimilar metal through an electrolyte. pure water is total resistant but the tiniest amount of contamination and it will conduct.
You need de-ionised water and a good additive and change it by the book. It was not so critical when the engine was all cast iron but a common problem is the alli head corroding.
The coolant will need changing on a time basis as much as milage so I would give it some thought if the car sits in the shed a lot of the time
Toyota cruiser utes had a prob with the radiator twisting with the chassis on hard terrain. You could get away with blocking off the affected area with solder or epoxy but a temporary fix that.
Some of you will know all this but I repeat it for the benefit of those who dont
And I have been known to be wrong.
Owen
266280
Reply By: Gerhardp1 - Friday, Oct 12, 2007 at 11:14
Mixing different coolants can create an ideal environment for accelerated corrosion of the radiator and other internal aluminium parts. I doubt that the national chain carries the recommended coolant for every vehicle, and the chance they have caused your corrosion is very high.
I have changed the Jackaroo coolant twice, but took a deep breath and paid for the "genuine" spare part from the dealer. I still have enough of the same batch to do 3 more changes.
My aluminium radiator is now 9+ years and no
sign of a problem.
When you get your new core fitted, I recommend thorough flushing out of all the current hybrid coolant, including thorough flushing of
the block, and go back to using the genuine part. Buy enough of the stuff to last you till you get rid of the car.
266285
Reply By: Member - Tonester (VIC) - Friday, Oct 12, 2007 at 14:02
Yeah, they suck. My toyota, dealer maintained, dealer provision of NEW radiator, and it died again in only 19mths - blamed on "poor maintenance" (theirs!), "mud", or "electrolysis", depending on when and who you spoke to. Not that they ever came to the party financially about it. The kicker was that it went back 5-6 times subsequently for additional leaks in the cooling system within the next 2mths, each time I was assured it was "fixed now", and "pressure tested" for hours.
266300
Reply By: PeteS - Friday, Oct 12, 2007 at 18:37
Hi Garth
From Pradopoint: "I was waiting at a Toyota dealer for them to replace a faulty reversing sensor when I noticed that the mechanic had a probe of a multimeter in the water of my radiator. Realising what he was doing (looking for excessive current/Voltage in the coolant) I asked him if the level was ok, he advised me that toyota had revised the acceptable level down to 0.4 Volts. The maximum voltage allowed is 0.4V between the engine block and the coolant, and from the coolant to the chassis"
Mmmmmmmmm
PeteS
266331
Follow Up By: David N. - Saturday, Oct 13, 2007 at 18:31
Gee. I'm starting to worry about my seventeen year old radiator on my GQ- maybe I'll have to recore it soon.
Manufacturers should be able to make a radiator which lasts many many years. There is no excuse for the rad dropping dead after only a few! Poor design!
528587
Follow Up By: Member - Garth J (NSW) - Saturday, Oct 13, 2007 at 18:51
Pete,
Got the multimeter out this arvo and had a poke around!
Highest voltage was 0.3V between coolant and the metal of the new core.
Had 0.2??V between body parts ie block and earth screws on the guard to the coolant.
So basically the electrolysis and corrosion has already started!!! LOL.
Just shows you that earth's ain't all the same!
That 0.4V is a handy number to know.
I wonder if they
check the conductivity of the coolant as
well?
Garth
528590
Follow Up By: PeteS - Saturday, Oct 13, 2007 at 19:16
Hi Garth,
You know I seen the info on the voltage measurements a few months ago and recorded the info to do the checks myself. Yeah you guessed it, I have done zilch since about it.
I'll extract my digit and get the multimeter out on Angus tomorrow and let you know the results.
Pete S
528595
Follow Up By: Member - JohnR (Vic)&Moses - Saturday, Oct 13, 2007 at 19:40
You guys wouldn't need a battery in your Prados if you would only keep sufficient acid in your radiators. Would be +2ve if you had it all set right ;-)))))))
528605
Follow Up By: PeteS - Saturday, Oct 13, 2007 at 19:51
John,
Grrrrrrrrrrrrrreat idea. Radiator doubles as an aux. battery!!!!
Geez, you've really got me thinking now.
Lets see, what extra can I put in the KK to run off the new radiator/battery supply ;-)
Love it,
PeteS
528609
Follow Up By: Member - JohnR (Vic)&Moses - Saturday, Oct 13, 2007 at 20:33
Low intensity LEDs?
528629
Reply By: PeteS - Sunday, Oct 14, 2007 at 18:47
Hi Garth
Checked the coolant voltage on Angus today.
My multimeter is an auto range digital unit and I initially got some strange voltage readings. Poss. the probe reacted with the coolant initially? Anyway all settled down after a while and wherever I tried the readings it ranged between 200-300milli volts. By the way this was done with the engine off. I assume it is done that way?
I will
check this again every so often as I'm not confident the reading were consistant enough.
FYI, the link I obtained the initial information on is
Pradopoint
PeteS
266540
