Has Anyone Used One Of These???
Submitted: Friday, Oct 12, 2007 at 10:55
Steve from Top End Explorer Tours
I was lucky enouth to get a 68 lt Eva Kool Fridge for $1200 new, now I don't have a problem with the Eva Kool as I Know there good.
I also got an Eva Kool eva Power unit with it, this one has a battery charger in it, would these chargers be capable of charging a deep cell battery?
The Unit features a duel output a 10 amp (peak) 7.8 amps continuous rated power supply and a 7 amp fully regulated battery charging outlet.
Specs.
output voltage: acc outlet 12vdc and battery charger 14.8 VDC(normal).
load current: 10 amps(peak) 7.8 amps Cont. @ 12VDC and 7 amps charging@ 14.8VDCfully reg down to float of less than 1 amp.
Input: 100VAC to 240VAC, 50/60Hz (switch mode circuitry)
Input Current ( No Load ): 33 A @ 100VAC or 20mA @ 240VAC.
Input Current ( Full load): 2.4@ 100 VAC or 1 A @ 240 VAC.
Automatic short circuit and overload protection.
Ripple: Less than 20mV
Efficiency: 75%.
Cheers Steve.
Thanks In Advance.
Reply By: Gerhardp1 - Friday, Oct 12, 2007 at 11:32
I have a 50 Litre Evakool, with the same AC adapter/charger combo.
The charger has no problem charging a deep cycle battery.
The fridge is brilliant, I love it.
266287
Follow Up By: Steve from Top End Explorer Tours - Saturday, Oct 13, 2007 at 12:42
Gerhardp1
Thanks for your reply, It seems like you and I are the only ones that have one.
Steve.
528548
Reply By: Member - Uncle (NSW) - Sunday, Oct 14, 2007 at 09:38
G'day Steve, we have one as
well ,and as a charger they are fine , used
mine many times in the bush with the gennie. Just recently we bought a 15 amp smart charger though from Derek, and is just a tad quicker to charge our batteries when in a hurry etc while out and about. cheers Unc.
266474
