Winch mounting plate
Submitted: Sunday, Oct 14, 2007 at 21:57
Member - Iceman (VIC)
Hi All,
I am planning to purchase a 12,000 lbs winch for my 2006 GU Patrol. The Bull Bar that came with the truck is a Nissan installed bar. It has a place for the winch rollers but no where for the winch to be mounted as I can see. Do I need to go to Nissan for the mounting bracket or can I get them for any 4WD
shop.
Thanks, Iceman
Reply By: PradOz - Sunday, Oct 14, 2007 at 22:17
CANT REMEMBER WHERE BUT I HAVE SEEN IT. SO GOOGLE SOME WINCH MANUFACTURERS AND YOU SHOULD SEE THE ANSWER - HOPEFULLY....
266581
Follow Up By: Member - Iceman (VIC) - Sunday, Oct 14, 2007 at 22:29
Thanks ProdOz I did look but hard to fine but will keep trying
528808
Reply By: Member - Luke (SA) - Sunday, Oct 14, 2007 at 22:29
I don't class myself as a winch expert but from what I have seen I don't think you need a mounting plate on a Nissan winch bar.
There should be 4 holes in the front of your bar, the top two should hold the top two bolts of the winch and fair lead, the bottom two should hold the bottom bolts of the winch.
My theory is, the reason there are only the four at the front is that's where all the pressure will be on the bar any way
Also from what I have seen, That's how the 9500lbs Warns are mounted
I sit here waiting to be corrected by an "expert" :)
Cheers Luke
266582
Follow Up By: Member - Borgy.. (SA) - Sunday, Oct 14, 2007 at 22:36
Luke , i thought i had explained to you the reason why you cant mount the winch the way you say , next time you are around home remind me to show you my new winch and whay i cant mount it the way you say .......Cheers
528809
Reply By: 93 Navara - Sunday, Oct 14, 2007 at 22:47
Don't think you can fit above 9500 into Nissan bullbar. Only on aftermarket types
266585
Reply By: Peter McG (Member, Melbourne) - Monday, Oct 15, 2007 at 00:40
Iceman
If you're looking to mount a 12,000lb Ironman type winch then it will fit straight in by using the 4 mounting holes in the standard Nissan steel winch bar. This is exactly what I have on my car. No special mounting plate needed.
266587
Reply By: Robin Miller - Monday, Oct 15, 2007 at 07:45
Hi Iceman
Did
mine without a Bullbar as per members photo.
Flat steel plate across chassis rails mounting into 4 existing bolt holes.
Used 6mm plate which is to light without bracing.
Bit of fiddling around but came up ok
Robin Miller
266601
Follow Up By: Trevor M (SA) - Monday, Oct 15, 2007 at 23:43
Mine is also on a self made cradle on the chassis.
There are some photos in my gallery
Trev
528993
