Water in Fuel
Submitted: Thursday, Oct 18, 2007 at 07:16
Member - Howard T (QLD)
Number 1 son has a 03 Hilux 4x4 diesel. In the last month the warning light has come on twice for excess
water in the filter.
Am assuming he has got
water in the fuel
tank.
Is this a normal occurrence as I have had diesels for the last 30 years and never had this problem.
Not being mechanically minded should I get the
tank drained? I remember reading in a 4X4 mag that half a cup of metho in the
tank can help dissipate
water in the fuel.
Hope someone can put me right on this.
Howard.
Reply By: Member - Phil G (SA) - Thursday, Oct 18, 2007 at 08:29
The sensor is in the bottom of the fuel filter under the bonnet. Theres a stopcock under there that can be used to drain it immediately. Failure to do so can damage your expensive injector pump. Your handbook should tell you this!
267136
Reply By: Member - Howard T (QLD) - Thursday, Oct 18, 2007 at 08:46
Thanks Phil
Yes we have drained the filter both times as per the book. What my concern is is how much
water is in the tanks itself.
Howard.
267137
Follow Up By: Member - Phil G (SA) - Thursday, Oct 18, 2007 at 14:49
Howard,
As its happened twice, I'd be draining the
tank.
Sounds like a fair bit of
water - I'd be guessing it came out of the servo - I'd be getting my diesel elsewhere, preferably a
truck stop. But like Owen explained, condensation does occur, and the way to prevent that is to keep the tanks full. I guess your son would be like most boys, and keep the
tank empty!!
Diesel fuel treatments, like Chemtech are very cheap and guard against
water, algae etc. Just put 20mls in a
tank and a litre of the stuff costs about $25.
529577
Reply By: obee - Thursday, Oct 18, 2007 at 09:20
Air carries
water and air replaces fuel in the
tank. Condensation occurs and
water will build up slowly.
Water will dissipate slowly into the fuel and this can be helped along with fuel additive. The
water goes through the combustion process with the fuel.
A lot of
water in the fuel can come from various obvious sources but high humidity followed by cold nights can be a nuisance too. The drain on the filter is one thing but my advice is to get the vehicle level and drain any
water that will spread to the drain plug. Follow up with the filter drain and add a generous amount of additive which may help the injectors too.
That what I did last time I had
water in the
tank and it worked. Now I am reminded to put some additive in as it has been a year since the last dose. Keeping
water out keeps the fungus from growing and blocking the filter.
Owen
267141
Reply By: TerraFirma - Thursday, Oct 18, 2007 at 10:20
See what Diesel additives there are that will help move the water/moisture out. Metho helps in petrol engines, not sure about diesel. Fill up the
tank elsewhere and see how you go.
267155
Reply By: Laura aka diver 1 - Thursday, Oct 18, 2007 at 12:27
worked at a servo for 5 yrs and our secret was pour metho in....half a bottle for a full
tank.....
laura
267171
Follow Up By: Laura aka diver 1 - Thursday, Oct 18, 2007 at 14:56
sorry a bit plain on the explation Howard....was on the phone to Bucky...
If you suspect
water to be in the fuel...idles funny etc....then depending ow much fuel you have in the
tank depends how much you pour in....like i said half a bottle (500ml) per full
tank...
Dunno how it works - just does - metho soaks up the
water then it just gets used through the fuel....no harm done....
Thought this was the prblem with my old suzuki but it turned out that there was plastic stuck in the fuel lines ! ! ! ! I always get a little sus now when the car idles funny...
Laura
529580
Follow Up By: Member - Bucky (VIC) - Thursday, Oct 18, 2007 at 20:27
Hold everything !
Dosen't metho only work with petrol engines ????
Not too sure about Diesel !!
Need some more imput here....
Cheers all Bucky
529641
