Ot marine radio
Submitted: Thursday, Oct 25, 2007 at 11:12
Dave(NSW)
I have a GME GX294 radio which stopped working,checked fuses all ok pulled radio out of the boat and pulled cover off to fine it has had
water in it.Question is it worth repairing or cheaper/easier to buy a new one.Thanks in advance,
Dave....
Reply By: Member - joc45 (WA) - Thursday, Oct 25, 2007 at 11:26
Hi Dave,
Depends how long the
water has been in there! But it sounds like the fault is terminal, as corrosion is the big problem, aggravated by the power being on.
Normally, if you get sea
water in any electronics, remove power immediately, try to drain/shake off any
water immediately, and as soon as you can, rinse out (yes!) with fresh
water to remove the salt, then warm in an oven at about 50deg to dry out all
water. Don't overheat, as you will melt things and don't connect the power until you are sure that the device is completely dried out. You have nothing to lose, and everything to gain.
Even rescued a laptop this way.
Gerry
268267
Follow Up By: Dave(NSW) - Thursday, Oct 25, 2007 at 12:13
Hi joc45
The frame work is rusty and electric board has
water marks on it so I would say it is cactus,do you know if VHF is better to use than 27 meg & do you need a licence for it,we only go out side occasionally.
Cheers Dave...
530830
Follow Up By: Member - Andrew (QLD) - Thursday, Oct 25, 2007 at 12:35
You'll need a MROVCP (or MROCP) license for UHF marine, nothing for 27 meg.
530834
Reply By: age - Thursday, Oct 25, 2007 at 13:05
Latest GME GX300 27Mhz only $150 and waterproof. Cheaper no name brands for as little as $99.
Cheap insurance if needed in an emergency rather than relying on one that could be suss after
water damage - throw it and buy a new one.
A
268277
Follow Up By: Dave(NSW) - Thursday, Oct 25, 2007 at 14:19
age
The GME GX300 sounds like a good deal I'll look into it
Thanks DAVE...
530842
Reply By: TerraFirma - Thursday, Oct 25, 2007 at 14:54
Repairing a
water damaged device can be like chasing your tail , one thing after another, buy a new one.
268286
