04 Prado Bonnet
Submitted: Thursday, Nov 01, 2007 at 20:53
ThreadID: 51169 Views:2416 Replies:3 FollowUps:3
Hi all,
My wife and i just purchased a 04 gxl prado really happy with it. Just a question abou the bonnet it seems to rattle a little when driving. Not so much a noise but you can see it moving a little. The clip doesnt seem to be holding? Has anyone had any experiences or heard of this happening? Any possible solutions?
Reply By: Member - 120scruiser (NSW) - Thursday, Nov 01, 2007 at 21:05
Yeah its commong.
If you lift the bonnet and have a look in the front corner on either side you will see a round rubber piece. If you grabe this piece and screw it out a turn and then close the bonnet. That should secure it for you. These are the bonnet stops or rests what ever you want to call it.
Hope this helps
Scott
AnswerID: 269588
Follow Up By: andyroo - Thursday, Nov 01, 2007 at 22:32
thanks for that.
FollowupID: 532481
Follow Up By: Member - Davoe (Yalgoo) - Saturday, Nov 03, 2007 at 08:40
yep if you dont and travel alot of corragated roads the catch will flog out and fail
FollowupID: 532724
Reply By: Muddy doe (SA) - Friday, Nov 02, 2007 at 00:12
When you say the bonnet is moving..... is that in relation to the bullbar (if you have one that is!)?
On our prado we have the alloy factory bullbar and it does move around quite a lot on rougher roads and at first it did look a bit like the bonnet was moving up and down a bit.
Muddy
AnswerID: 269637
Reply By: traveller2 - Friday, Nov 02, 2007 at 08:40
The later model Prado's are also prone to body and chassis cracks when fitted with bullbars and winches, especially if used for what they were 'designed' for.
AnswerID: 269664
Follow Up By: Member - 120scruiser (NSW) - Friday, Nov 02, 2007 at 20:22
I think you will find its more the suspension set up than bars and winches. I have had an ARB steel bar with 9500 lb winch fitted from new and have had no cracks. I do run lovells and bilsteins which seem to do the trick.
Stock suspension are the ones that crack.
FollowupID: 532640
