vibration noise in hubs
Submitted: Friday, Nov 02, 2007 at 07:57
mark4
Hi i need help with my 96 gq Patrol, when driving with hubs locked in and the gear shift in 2wd i get a loud humming noise and slight vibrations, when i take the hubs out of lock the problem goes away.
does any body no what may cause this any help will be much appreciated.
Thanks in advance.
Reply By: traveller2 - Friday, Nov 02, 2007 at 08:36
There will be something in the driveline out of balance or worn, usually the tailshaft, uni's or sliding joint would be the first suspects.
It could also be caused by driveline angles if you have changed/lifted the
suspension.
269662
Reply By: ExplorOz Team - Kerry W (QLD) - Friday, Nov 02, 2007 at 09:20
I think just about every GQ does this , its just a slight imbalance in the drive line to the front diff, it shouldnt get any worse.
Kerry W
| Kerry W (Qld)
-Helen KellerLifetime Member My Profile My Blog Send Message |
269671
