Choosing my new 4WD
Submitted: Friday, Nov 02, 2007 at 12:30
rond
Hello
I am on the market to buy a new 4WD to tow my 2500 Kg caravan, As I need a 4WD with a good towing and carrying capacity, I was looking the latest RA Rodeo dual cab auto with the 3 lt diesel engine, Does anyone would be able to tell me if you know somebody with the similar caravan and vehicle and if the car match the caravan weight
Ron
Reply By: Member - Alan H (Narangba QLD - Friday, Nov 02, 2007 at 13:29
Ron
You need to start with specs on towbar capacity, towball weight and the Gross Vehicle Mass for a specific vehicle.
These all vary form vehicle to vehicle.
A rule of thumb also to keep in mind is that the tow vehicle needs to be heavier than the towed vehicle for braking and control
Else you may be illegal and have insurnace problems.
Hope you find what you are looking - look at the spec sheets for the Rodeo.
269708
Follow Up By: Faulic_McVitte - Friday, Nov 02, 2007 at 13:53
WRONG the tow vehicle does not need to be heavier than the caravan.
The caravan can be 1.5:1 so the caravan could weigh 1.5T and the vehicle 1T
Personally I would not have a caravan heavier than the vehicle. On my present setup my vehicle is 200kg heavier and would not like the caravan to be any heavier.
532579
Follow Up By:- Friday, Nov 02, 2007 at 15:00
Alan H says nothing about "impossible" or "illegal", but rather "rule of thumb". And I agree with him fully - unless you have proper hydraulic or pneumatic brakes (not electric or push-style one) on your trailer it would be safer when towing vehicle as least as heavy as towed. I just shake my head when I see from time to time idiots towing huge caravans by something like Magna or Camry. Kamikazes.
532593
Follow Up By: disco1942 - Friday, Nov 02, 2007 at 18:10
FollowUp 1 of 2
The 1.5:1 ratio only applies to vehicles where the manufacturer has not specified a maximum towing limit. If they have then the manufacturers limit is the maximum by law. Before the unified traffic laws were introduced the more enlightened states had a 1:1 ratio.
FollowUp 2 of 2
Electric brakes with a good controller (which includes a deceleration sensor) are as good as vacuum brakes.
Both the Magnas and Camrys I have seen the specs for weigh more than the manufacturers maximum permitted tow weights.
532617
Reply By: AdlelaideGeorge - Friday, Nov 02, 2007 at 13:47
Have a look at the new Triton - max towing cap 2.3 tonnes
Happy days
George
269709
Follow Up By: Faulic_McVitte - Friday, Nov 02, 2007 at 14:05
Triton 3.2T is a magic tow vehicle. Cruises effortlessly in 5th gear towing the van. Fuel consumption is 7.3km/L towing which is great.
532581
Follow Up By: age - Friday, Nov 02, 2007 at 14:08
Why would he look at the Triton with a 2300kg tow capacity when his van is 2500kg
A
532582
Follow Up By: AdlelaideGeorge - Friday, Nov 02, 2007 at 14:39
well age - (I am going to do what so many posters do now - a back hander) anyone with 1/2 a brain would like looking at Tritons!!!!!
Happy days
George
532590
Follow Up By: Hairy (NT) - Friday, Nov 02, 2007 at 14:59
AdlelaideGeorge,
Does that mean the average person with a full brain woulnt look at sheet box but a real car? Perhaps a Toyota or even a Nissan?
LOL
532592
Follow Up By: age - Friday, Nov 02, 2007 at 16:38
But
Adelaide George
You missed the point - He cannot legally tow his nominated van with the Triton by a long shot
Triton max tow capacity = 2300kg
His van = 2500kg
= his van is 200kg more than the Triton is nominated to tow
= illegal and dangerous
Backhander - whoomp
532605
Follow Up By: AdlelaideGeorge - Friday, Nov 02, 2007 at 19:43
no age I really didn't miss the point - just being a bit flippant because
1. got to get a plug in for the Triton and
2. it's Friday and feeling good!
PS Any idea how I find out what I wrote in thread 51200 - it was deemed unsuitable to remain in the
forum and removed but because I can't see it I've no idea why!!!!!
ha ha
Happy days
George
532629
Reply By: Dazmit - Friday, Nov 02, 2007 at 14:12
Is that 2.5 tonne van an actual weigh bridge reading with it loaded or a guesstimate from the plated weight ??If the later then get it weighed as most plated weights and guesstimates are usually 200 - 500kg under the true weight.
Once you have an accurate weight then look at vehicles max capacity.
BTW the 2 suggestions of a Triton with 2.3 t capacity with a 2.5t van aren't the smartest unless you like having an illegal rig on the road.
Darryl
Brisbane
269714
Follow Up By: Member - Oldbaz. NSW. - Friday, Nov 02, 2007 at 16:50
Now there's a bloke with a few brains, get an accurate weight
then add the load & start from there. Personally I think Darryl
needs a Cruiser... new 200 series V8 Diesel should do it....
cheers...oldbaz.
532607
Reply By: Member - Norm C (QLD) - Friday, Nov 02, 2007 at 14:14
Ron, I think you have to move away from the 'lighter' 3 Litre Utes. George suggested the Triton wiith 2.3T tow capacity, but your van is 2.5T.
I have a new model Hilux and it tows my 1.5T CT beautifully, but I would not want to tow more than 2T with it over long distances.
My rule of thumb is to use only 80% (max) of your vehicles tow capacity for it's standard load on long distance travelling. No basis for this other than a safetly margin and not flogging the vehicle more than necessary.
If your 2.5 T van is fully loaded for travel, I reckon you should be aiming at a vehicle with 3T tow capacity. If the 2.5T does not include all the clothes, food,
water and other stuff you put in it, perhaps you need to be targeting 3.5 T tow capacity vehicles.
The new Navara is rated to tow 3T (I think), but it is a very similar vehicle to the others in it's class. I wouldn't regularly tow that much with one.
I think you might need a Land Cruiser, Patrol or similar to do the job. They are expensive and difficult to get, but the new LC ute, set up with a canopy for load carrying seems to be an ideal touring and towing vehicle (but no ABS or airbags). It is my dream vehicle anyway, once the heat goes out of the market so they get a bit cheaper.
Good luck with your research.
Norm C
269715
Follow Up By: AdlelaideGeorge - Friday, Nov 02, 2007 at 14:45
yep - Navara is 3 tonnes - better choice under the circumstances - althopugh of course it won't be a Triton!
Beats me how the manufacturers work these capacities out though
George
532591
Reply By: splits - Friday, Nov 02, 2007 at 14:54
Ron
All I can say is buy something that will give you plenty in reserve. Your van is heavy and if 2500kg is the empty weight, it will most likely go over 3000kg when fully loaded. It will be a fair load on many cars and will be even worse if you take it through hilly country on unsealed roads.
I think a 3 litre will definately pull it, providing everything is legal, but how comfortable will it be? Caravaning is great when you can cruise along and hardly even notice the van is on the back. It can be very disappointing when you are forever changing down through the gears, the fuel gauge is dropping like there is a hole in the
tank, the temperature gauge is up a little and the postman goes flying past you uphill on his little bike.
I was at the Milmerran
Camp Oven Festival last year and there were about thirty or so members of the Kedron club in attendance. They all had big heavy off road vans and from what I could see, it looked all were being towed by Cruisers and Patrols.
I would be looking at nothing smaller than a V8 diesel for a van that size. Even if it is a little overkill, you won't regret it.
Brian
269721
Reply By: disco1942 - Friday, Nov 02, 2007 at 18:40
Ron
What is the ATM of your van? That is the figure you have to look at when deciding whether the proposed vehicle is capable of towing your van.
Look at this link. Looking at the specifications quoted in it both the Rodeo and Navara can be legally used to tow the van if the ATM is below 3,000kg.
I would like to add support to those who suggest checking the weight of your van. If it's tare weight is 2,500kg it's ATM will probably be 2,900kg (manufacturers commonly allow 400kg load in a twin axle van.) The big problem with van weights is many of us have purchased new vans and found the registered tare weight is not accurate - and none of them were lighter than stated. Also if accessories like awnings, air conditioners and solar systems have been added after the van was delivered to your agent then these will probably not have been included in the tare weight and therefore your van has not been correctly registered.
269744
Reply By: Member - Barnesy (SA) - Friday, Nov 02, 2007 at 21:08
Go the heaviest 4wd you can get, Patrol or Lancruiser. 6 or 8 cylinder. Little engines and smaller cars still struggle when towing heavy vans, whereas the bigger fourbies do it with ease and still have plenty in reserve for hills, overtaking and emergencies.
Can't remember exactly the figures but a few years ago i read the carrying capacity of the f250 was only around 100kg more than the Rodeo!
Take manufacturers claims about towing capacity with a grain of salt and go for size.
Barnesy
269776
Reply By: Laura aka diver 1 - Friday, Nov 02, 2007 at 22:50
80 series for sale...2500kg tow cpacity...LOL...
Laura
269808
Reply By: rond - Saturday, Nov 03, 2007 at 05:04
Thanks for your feedback, my van is 2550 Kg GVM on the wieghtbridge.
Rond
269820
