Actuator 2000 Jack $1000
Submitted: Saturday, Nov 03, 2007 at 23:12
ThreadID: 51259 Views:2209 Replies:4 FollowUps:3
I have heard the price to supply and fit actuator (one piece lifting mechanism for Jack is about $1000)
Does anyone have any eperience of this?
Yenchy
P.S. Is there a second hand / wrecker in Stdney that anyone can recommend?
You could toss in reliable mechanic if you knoe one too and don't mind
Yenchy
Reply By: WDR - Saturday, Nov 03, 2007 at 23:13
I always forget something - I am talking about electric front LHS window
AnswerID: 269960
Follow Up By: disco driver - Saturday, Nov 03, 2007 at 23:41
Hi WDR,
Not much help, but if it's any consolation the 356 Porsche Carrera GT has a leather strap with holes in it which is used to raise and lower the windows. It is fixed to the bottom of the window and comes out the top of the door.
Might be an answer for a Jack. LOL!
FWIW an electrically controlled external Rear Vision mirror for my Disco was quoted at $750 fitted.
Found a 2nd hand one for $160 and took about three quarters of an hour to fit.
Good Luck with your search.
Disco
FollowupID: 532869
Follow Up By: obee - Monday, Nov 05, 2007 at 10:12
I did precisely that on my old hilux and lived with it for long time before I found a cheap replacement
Owen
FollowupID: 533118
Reply By: Gerhardp1 - Sunday, Nov 04, 2007 at 00:05
I suggest a panelbeater to do the fitting, since they do this stuff all the time.
They should also be able to source a second hand part from a wrecker as well, otherwise grab the yellow pages for wreckers and let your fingers do the walking. You could also google for a 4x4 wrecker.
Your other option is to get the parts from the USA, this place has the electric motor for about $US120 and shipping would be about $US40 http://www.rockauto.com There are also other places over there, try a google for Isuzu Trooper parts. You can get a part number listing here which could be helpful http://www.myisuzuparts.com
AnswerID: 269967
Follow Up By: Gerhardp1 - Sunday, Nov 04, 2007 at 00:12
Don't know what happened there - part of my post disappeared.
This place for parts possibility http://www.rockauto.com
The other link for part numbers and parts diagrams which could help in a US search. There are other places over there which sell all sorts of Jack parts, do a google for Isuzu Trooper parts or visit planetisuzu.com for links.
I just bought a timing belt, water pump, idler and tensioner pully kit for $AU159 landed at my door. I didn't even bother pricing the parts locally. A couple of years ago I got a new O2 sensor from the US for less than $AU100 when the local part is $660 - glad I didn't buy it here, because it wasn't faulty.....
FollowupID: 532872
Reply By: Member - Noldi (WA) - Sunday, Nov 04, 2007 at 10:25
Hi Yenchy,
Ha a problem on the jack with the switch for the electric window (quoted $300) Used the one from the rear window as there are only the two of us.
rgds
ian
AnswerID: 269994
Reply By: Member - Matt (Perth-WA) - Monday, Nov 05, 2007 at 15:56
WDR...had to replace the lifer mechanism in my Brother Isuzu MU. I bet its identical to the Jack. Was quoted hundreds for genuine but found the entire mech after market and brand new for about $200 at a wrecker in Perth.
Removed the motor and fitted to new lifter and 10 mins later I had it in the door, hooked up and good as new.
I would try the wreckers for aftermarket NEW parts.
Otherwise I used to deal with a Commercial wrecker in Smithfield in Sydney...great and always available bits.
All the best
Matt.
AnswerID: 270155
