2WD towing Off road van - is it feasible?
Submitted: Sunday, Nov 04, 2007 at 16:20
Newbiesb
Hi, we're lloking at buying an off road goldtream, but can't afford to upgrade the tow vehicle yet. Is it possible to tow a van set up for off road with a
sedan (The sendan is a commodore fitted with electric brakes, weight distribution hitch and haymen reece 2200kg tow kit) the van will definately be lighter to tow than the horse float i currently tow. We don't really want to buy a van, then have to change it over in 12-24 months when we look at upgrading the vehicle.
Any advise is appreciated.
Reply By: Andrew from Vivid Adventures - Sunday, Nov 04, 2007 at 16:22
possible - it will depend on how high off the ground the drawbar is, and whether the hitch can/should be adjusted that high.
270046
Follow Up By: Newbiesb - Sunday, Nov 04, 2007 at 17:06
Thanks for the reply. Do you know how high the standard tow hitch on an off road van be? (i just noticed i had a dyslexic keyboard when i submittted the initial post - oh
well - it is Sunday)
533001
Follow Up By: Andrew from Vivid Adventures - Sunday, Nov 04, 2007 at 17:32
Depends on the van... and the choice of
wheels.
It can be definitively too high, but it depends a lot of the design.
533006
Follow Up By: Newbiesb - Sunday, Nov 04, 2007 at 17:45
Could we put standard car
wheels on the van,then change the
wheels when we upgrade to a 4wd? Would that be enough to overcome a problem? And if not, what else would we need to look out for? We're looking at a Goldtream Storm off road version and i'd prefer to know before we purchase as we need to keep it all in mind when buying. We won't be purchasing the camper new.
533007
Follow Up By: Andrew from Vivid Adventures - Sunday, Nov 04, 2007 at 17:52
Should be no problem, but measure the van height before you buy it and go to a Hayman Reece (or whatever brand hitch manufacturer you have) dealer and tell them what height you need it and what the cost of the appropriate hitch would be.
The Storm is a pretty standard pop up...
One thing to watch changing
wheels is that the annex, if it has one, may no longer touch the ground appropriately so changing
wheels may not be an option.
Andrew.
533008
Follow Up By: disco driver - Sunday, Nov 04, 2007 at 21:10
Hi Newbiesb,
If you are contemplating changing
wheels, be aware of the necessary rim clearances and offsets for brake drums.
Changing the axle from under to over
the springs sounds relatively simple but it's not necessarily so.
There are things like axle to chassis clearance, wheel to body clearance and rearranging brakelines etc to consider.
In my opinion, not worth the effort for a short time period.
The most effective option is to lift the towball height to match the van. Most WDH's have some adjustments but if these do not give sufficient adjustment, there are aftermarket hitch tongues with much more adjustment available that will fit the square receiver on your hitch to suit your van.
Sorry it's a bit longwinded but hope it helps you to get set up
Disco.
533065
Follow Up By: disco1942 - Sunday, Nov 04, 2007 at 23:05
The centre of a 50 mm ball should be between 350 & 420 mm from the ground when fully loaded. Many of the off road van and camper trailer manufacturers actually build their drawbars to conform with this regulation. The ball mount shank can be turned over if the drawbar is above the standard.
533081
Reply By: TassieDave - Sunday, Nov 04, 2007 at 16:45
My Parents towed a new offroad camper behind a commodore for about ten years before they got a 4wd. Looked very funny, they didn't care.
270050
Follow Up By: Newbiesb - Sunday, Nov 04, 2007 at 17:04
Thanks for the reply. Do you know if your parents had to modify the towing hitch on either the car or the van? I just aren't sure how the two heights would join up.
532999
Follow Up By: TassieDave - Sunday, Nov 04, 2007 at 17:08
No they didn't do anything, the back of the trailer used to point to the sky. There camper trailer is a long way under the commodore's limits. They have a treg hitch on the camper.
533003
Follow Up By: Member - Terry G (NSW) - Sunday, Nov 04, 2007 at 19:03
Don't want to point out the bleedin obvious, but if the tail is pointing to the sky doesn't that concern you about weight distribution, braking, lack of control and not to mention the effect on a dometic fridge inside.
tessa
533025
Follow Up By: Newbiesb - Sunday, Nov 04, 2007 at 20:28
TerryG, Soory, but if it was 'bleedin' obvious, i wouldn't be asking. I'm sure that not everyoone know 'the obvious'. Isn't that what forums are helpful with - helping those new to this?
533052
Follow Up By: Member - Terry G (NSW) - Monday, Nov 05, 2007 at 07:15
newbiesb
sorry if I upset you - the followup that I posted was meant for Tassiedave not for you. I was simply trying to get the same message across as all the other posters.
tessa
533093
Reply By: Member - JohnR (Vic)&Moses - Sunday, Nov 04, 2007 at 18:04
Know some folks with an offroad Karavan being towed by a Falcon tray body with a canopy/tool box. They just get concious that they can't go to more offroad than some can. Otherwise it is still under control but you are talking of a towed Karavan of up to two tonnes.
270059
Reply By: Stoker - Sunday, Nov 04, 2007 at 19:23
Newbies
Just make sure the van is level when hooked up and the bars are on. If not level adjust the towball hitch up or down by shifting it to higher or lower bolt holes. If still no joy turn the towball hitch upside down and adjust again. You are bound to find a setting to suit you.
270071
Follow Up By: HGMonaro - Sunday, Nov 04, 2007 at 19:33
which WDH have you got?
533036
Follow Up By: HGMonaro - Sunday, Nov 04, 2007 at 19:34
of course that was supposed to be a reply not a followup
533037
Follow Up By: Newbiesb - Sunday, Nov 04, 2007 at 20:27
Hi HG MOnaro. I don't know what 'model' of WDH L have. It was fitted by the Holden dealer that sold me the car.. Wigger, i'll look up the info. Thanks.
533050
Reply By: Trevor R (QLD) - Sunday, Nov 04, 2007 at 19:50
If height of van is a prob, get the hitch put under the A-Frame of the van instead of the normal on top of A-Frame setup, this should drop hitch height by at least 4-6 inches. Then reverse back to factory settings once you get the 4b.
No other probs in my eyes, if your are within legal weights.
Cheers, Trevor.
270076
Reply By: 96 GXL 80 series - Sunday, Nov 04, 2007 at 20:17
You have a couple of options.
1 is set up up the draw bar with a spirit level and measure from the ground up to the trailer hitch, then check that measurement against the tow hitch on your car.
See what the difference is.
Hayman Reece make height adjustable hitches so this might get you out of trouble.
Another one is have a look at the way the Axel and spring is set up.
If the Axel is on top of the spring to get extra height, then you can swap them around and have the spring under the Axel so this will lower the ride height of the van.
When you update your vehicle you can swap it around again.
But as pointed out if you have an annexe then this will render it not right unless you have chocks or stacka jacks to raise the van in a
camping area.
270083
Follow Up By: 96 GXL 80 series - Sunday, Nov 04, 2007 at 20:19
I meant if the Axel is under the spring to get extra height.
533047
Follow Up By: Newbiesb - Sunday, Nov 04, 2007 at 20:31
Thanx heaps, this is very helpful. It gives me sonething to work on when purchasing the van and then converting back to the 4WD i dream about. Unfortunately, we can't afford both straight away, hence having to improvise for a short while.
533055
Reply By: awill4x4 - Monday, Nov 05, 2007 at 13:42
Newbiesb, just make sure you use a Hayman Reece weight distributing hitch and you won't have any problems.
They come with a height adjustable towbar hitch that is offset and can be used either pointing up or down, just reverse the head unit that the torsion bars attach to to suit your vehicle.
Have a look at the Hayman Reece site
Haymen Reece and look for it under Products then "weight distribution"
Whether your weight distribution hitch is the same as this I don't know but this is the only hitch I will ever use, it's brilliant.
If you have the newer versions of this type of hitch they have a cam adjustable system for the towball so the towball is vertical regardless of the angle of the tow hitch on the car.
Regards Andrew.
270143
Follow Up By: Newbiesb - Monday, Nov 05, 2007 at 14:37
Thanks Andrew, i didn't even think of looking at the Haymen Reece website. Must be having one of my 'blonde' moments. I have looked at their site and emailed them for more info.
Thanks again
533149
