Advice about a second set of wheels and tyres
Submitted: Monday, Nov 05, 2007 at 14:42
60 series Dave
G'day all. I am currently running a set of Motorway Bronco 205R16 but have found that they have suffered significant wear in only 12 months, and need to be replaced. Since my car is also my daily driver I want to run a highway terrain tyre on the current 16 inch
wheels and purchase another set of
wheels and tyres with a more aggressive A/T or M/T pattern for weekends.
I want to keep the tyre sizes as close to standard as possible. What would your suggestions be for the around town tyres, and the bush set?
Reply By: TD100 - Monday, Nov 05, 2007 at 19:18
Hi Dave,i run Kuhmo Venture AT for day to day running and towing(285/75/16s) and for touring i run Pro Comp Mud Terrains(305/70/16s)very good outback and mud tyre,given them hell and still got more in them,will stick with them when these are worn out.cheers Paul
270203
Reply By: Laura aka diver 1 - Monday, Nov 05, 2007 at 20:03
Our roadies are Maxxis somethings.....get around 60,000km plus out of them....brilliant!! Tey have even handled really
well on dirt roads and when needing roadies again will get them....
Laura
270216
Reply By: madfisher - Monday, Nov 05, 2007 at 20:39
Dave if you have a 60 series you have the wrong size tyre. 205 s was fitted to hiluxs and 4runners. 60s normally run 750 16s or 235 16 . Your poor wear could be explained by this and your gearing and ground clearance would suffer.
Cheers Pete
270229
Follow Up By: Member - Phil G (SA) - Monday, Nov 05, 2007 at 21:26
Yep, spot on Pete.
533231
