Re Post 51205 Nissan 3.0 Belt Tensioner
Submitted: Tuesday, Nov 06, 2007 at 12:43
ThreadID: 51332 Views:2055 Replies:0 FollowUps:0
You can replace the bearing in the 3.0litre ZD30 engine belt tensioner. Part no 62203. It is about 20 bucks so alot cheaper than Mr Nissans $360.00.
However the bearing is 2mm wider but not a problem so long as you press it in to the correct spot (observe off old one prior to removal). The original pulley and retaining bolt is used.
Hope this helps anyone
Scott
