Hayman Reece drawbar pin.
Submitted: Friday, Nov 09, 2007 at 18:50
Member - Axle
Chasing a electrical prob in the rear end of the defender, (Landrovers!!), and the towbar had to come off, ten bolts holding it on, very solid setup. But i still can't get used to that little 12mm pin which is supposed to have about a 12t shear rating, that holds the drawbar, it dosen't look right and probably isn't. Think i'll upgrade the safety chains.
Cheers Axle.
Reply By: Member - Phil G (SA) - Friday, Nov 09, 2007 at 19:27
12mm????
Every pin I've seen is 16mm.
Bloody LandRovers :-)))
270956
Follow Up By: Member - Axle - Friday, Nov 09, 2007 at 19:36
HAHAHA,! maybe its worn a bit thin From towing toyos!...lol.
Your right!, getting it wrong there, Just got to get the new glasses.
cheers.
533970
Reply By: 96 GXL 80 series - Friday, Nov 09, 2007 at 20:57
Being brought up in the building trade, a 3" nail has a shear weight of 1 Ton, so that should give you some idea.
270975
Follow Up By: Member - Axle - Friday, Nov 09, 2007 at 21:06
MMMMMM!, so if i loose my pin, i can use a 3in nail to get out of trouble providing i don't pull in excess of 1ton....:))))))).
Axle.
533981
Reply By: disco1942 - Friday, Nov 09, 2007 at 21:25
If you are using WDH you don't need the pin at all. HR used to demonstrate this - they would remove the pin, drive around in some figure 8s and they would replace the pin without having to shift anything. I have seen friends vans arrive at some rallies with no pin - they had been interrupted when hitching up at home and forgotten to complete the replacement of the head before hitching up.
270983
Reply By: 96 GXL 80 series - Friday, Nov 09, 2007 at 21:43
At the shear point yes you could but not holding each end and pulling in the middle.
270986
Follow Up By: Member - Axle - Friday, Nov 09, 2007 at 22:06
I know what your saying mate,
Cheers.
533995
