electric hubs
Submitted: Sunday, Nov 11, 2007 at 01:13
ThreadID: 51495 Views:2526 Replies:4 FollowUps:7
Hi everyone.....some helpful advice on the correct procedure to adjust the brake shoes (al-ko) on a tandem caravan...they are electric hubs..lead set incorporate handbrake....cheers phil
Reply By: Member - Rotord - Sunday, Nov 11, 2007 at 02:03
Hello Phillip
You will find a good set of instuctions in Jayco caravan manuals . Unfortunately I am in Port Hedland and my manual is in Inverloch , but you may be able to borrow one locally .
AnswerID: 271168
Follow Up By: Member - Phillip S (WA) - Sunday, Nov 11, 2007 at 10:48
Thanks Rotor.....Phil
FollowupID: 534168
Reply By: Member - Bucky (VIC) - Sunday, Nov 11, 2007 at 04:32
I had major problems with our Camper trailer breaks. ( Electric )
Always locking up, no matter what I did
Read my posts it might help you
ThreadID: 40396
ThreadID: 40606
Now when you jack up each wheel to adjust them up, you will hear the magnets scraping on the drum as well, don't let that put you off, just look for spinning resistance. Say about 1/2 a revolution, then give it one more click, it should not spin. So I them back it off 2 clicks.
Do the same on both sides
With the electric adjustment, follow the manual. If you have a Techoncha voyager controller, I can burn you a copy of the instructional DVD.
Basically do what they tell you, then I back off the corse dial a little, and have not had any more lock ups.
Cheers MAte
Bucky
AnswerID: 271173
Follow Up By: Member - Phillip S (WA) - Sunday, Nov 11, 2007 at 10:44
Bucky....thanks mate, much appreciated....Phil
FollowupID: 534165
Reply By: MEMBER - Darian (SA) - Sunday, Nov 11, 2007 at 07:53
Got the same gear on my Campomatic. Been good to date (4 years) - getting worn now and will be up for shoes, magnets and drum machining before the next big trip. To adjust the shoe clearance, the common tool for that purpose is cheap and very handy - Repco et al will have one - has screwdriver type ends on it but the bent ends are handy. Re the little adjustment access hole on the lower-back of the hub - crawl under and have a look in there with a light - just so you can see the lugs on the spindle - makes it easier to engage them with the tool, when you know what is there. I take them up to a heavy drag (not quite locked solid), and then back off about 10 clicks. Re which way to swing the tool ? If you put the tool in, engage a lug and swing your outer end of the tool UP, this will increase the shoe clearance (loosen).
AnswerID: 271181
Follow Up By: Member - Phillip S (WA) - Sunday, Nov 11, 2007 at 10:46
Darian....many thanks....Phil
FollowupID: 534166
Reply By: Ray - Sunday, Nov 11, 2007 at 08:17
Initially I check mine with the hubs off, like when I'm doing wheel bearings. After inspecting the drums, the magnets and shoes, I use a set of Verniers to check the O.D. of the shoes and ensure that they are all within a micky whisker and the carry out the final adjustment as previous people have explained
AnswerID: 271184
Follow Up By: Member - Phillip S (WA) - Sunday, Nov 11, 2007 at 10:47
Thanks Ray....you all have been very helpful....cheers Phil
FollowupID: 534167
Follow Up By: Member - Bucky (VIC) - Monday, Nov 12, 2007 at 08:42
Magnet replacement,,
Have not done mine yet ,,
Any thoughts on when, or in what state they should be in, before thats done ,,
Everything works fine, so I guess if it ain't broke, don't fix it, or is there a minimim with this one ?
Bucky
FollowupID: 534281
Follow Up By: Member - Phillip S (WA) - Monday, Nov 12, 2007 at 23:03
Bucky...I googled "al-ko electric hub brake adjustment" and ticked the oz search only annd found a RVMAA caravan handbook which describes and shows in detail all we need to know about these ([PDF] RVMAA Owners Handbook) brakes and a lot of other stuff as well....about 66 pages of it.....rvmaa.com.au/RVMAA_owners_handbook.pdf ....check it out...cheers Phil
FollowupID: 534408
Follow Up By: Member - Bucky (VIC) - Tuesday, Nov 13, 2007 at 15:08
Spot on Phil
Wish I had found that a lot earlier, but I did get a lot of good Ideas from ExplorOz. And of course the couple of obligatory phone calls.
Cheers MAte
Bucky
FollowupID: 534489
