LPG gas cylinder inspections
Submitted: Sunday, Nov 11, 2007 at 18:06
ThreadID: 51509 Views:16629 Replies:7 FollowUps:14
I'm after info regarding gas cylinders in vehicles that are due for 10 year inspection.
Do they get removed or tested in vehicle, or are they replaced.
Any idea on cost of an inspection would be of help as guidance, I'm considering purchasing vehicle (cheapy) with gas and was after a rough idea on what is was gunna cost, or find an alternate vehicle.
Shane
Reply By: DIO - Sunday, Nov 11, 2007 at 18:49
Cosy of checking used to in the region of $60 - $80. It must be carried out by an approved testing station. If any faults are found in the cylinder or attachments, the tank may be condemned - unfit for further usage and faulty parts may be replaced. Don't take any chances with gas cylinders in vehicles. the results are often fatal and at least catastrophic. Some States require testing (or proof of) before renewal of registration to a new owner.
AnswerID: 271253
Follow Up By: Rock Crawler - Sunday, Nov 11, 2007 at 18:53
I agree with most things stated above , but I think you will find the cost more expensive , i hope I am wrong , cheerrs
FollowupID: 534218
Follow Up By: 96 GXL 80 series - Sunday, Nov 11, 2007 at 20:24
Shane,
not sure on QLD laws now but the seller used to have to supply a Roadworthy inspection with the vehicle and if fitted with LPG the same thing.
Ring up Gas Research and they will give you the information you need, re price etc.
QLD Transport will also be able to tell you.
FollowupID: 534228
Follow Up By: Andrew-rodeo - Sunday, Nov 11, 2007 at 20:44
Cost is about right, usually around the $80 mark, but you need to add the cost of someone to take it out and replace it. depending on the car you might be up for a couple of hours labour for that.
FollowupID: 534231
Follow Up By: Member - Shane D (QLD) - Sunday, Nov 11, 2007 at 21:53
Thanks Dio,
Qld does require inspection befor re-rego, Same in most states, but the inspection I need to get info on is the big 10 yearly one where I beleive the structual integrity of the cylinder gets tested.
Am getting this thing cheap(if I get it) Doin the research before it gets beyond cheap.
Shane
FollowupID: 534246
Reply By: Member - Mark E (VIC) - Sunday, Nov 11, 2007 at 20:04
I just had one done in NSW whilst travelling.Taree, I think. (Taree gas and gear??) It cost $38 including the gas refill (3.3kg). They check the (empty) cylinder, replace the ?valve in the top and then stamp the bottom of the cylinder with confirmation that it's passed inspection. $60 - 80 sounds a little pricey to me. My CT has Primus bottles, thus the need to have them inspected as other types wont fit the space.
Anyone know who does them in Melbourne?
Mark
AnswerID: 271263
Follow Up By: Gerhardp1 - Sunday, Nov 11, 2007 at 21:09
Portable bottles are a slightly different proposition to the 80-100litre LPG tank installed in a car :)
FollowupID: 534236
Follow Up By: Member - Mark E (VIC) - Sunday, Nov 11, 2007 at 22:58
Woops,,,,,, misread that one!!
FollowupID: 534261
Reply By: Trevor R (QLD) - Sunday, Nov 11, 2007 at 20:19
Diesel Blizzard for sale, needs no gas inspection LOL!!!!
AnswerID: 271266
Follow Up By: Member - Shane D (QLD) - Sunday, Nov 11, 2007 at 21:37
Actually Trevor, I did consider the blizzard, just not quite big enough
FollowupID: 534242
Reply By: Member - Debbie R (SA) - Sunday, Nov 11, 2007 at 20:38
Shane D,
If I read your thread correctly, you are talking about your vehicle cylinder not BBQ!!!! From memory I had my son's car done about 3 years ago in SA. Is not cheap!! I can't remember the exact cost but I believe it was around 200 maybe more. Just remember don't have it done if you have a full tank cause they empty it go with a near empty tank. By the way here in SA, you can have your car defected if the compliance plate on the LPG tank is not up to date.
Debbie
AnswerID: 271269
Follow Up By: Member - Shane D (QLD) - Monday, Nov 12, 2007 at 08:06
Thanks Debbie
You read right, thanks for the tip on going in with tank near empty
Shane
FollowupID: 534277
Reply By: Member - Shane D (QLD) - Sunday, Nov 11, 2007 at 21:47
Thanks to the reply's thus far,
In Queensland the same rule applies with regards to inspections of gas cylinders on vehicle transfer (being part of rego), but the vehicle I'm looking at is unreg. and also the tank is out of date(10 yearly inspection which is the big one.
Love to here from some-one who has been thru this process recently
Shane
AnswerID: 271293
Follow Up By: Allan F (Gold Coast) - Tuesday, Nov 13, 2007 at 07:15
Hi Shane,
in Qld the vehicle will need a roadworthy and a current gas certificate so it can be registered. The cost of testing the cylinder is between $180 and $230 depending if it is a multi valve or 4 valve cylinder plus the cost of remove and replace. The valves are replaced by the tank tester at this time and are included in this cost. Just be aware that through experience I have found that at 10 years the converter also starts to give trouble and may need replacing.
Cheers Allan
FollowupID: 534434
Follow Up By: Member - Shane D (QLD) - Tuesday, Nov 13, 2007 at 07:41
Thanks Alan,
I've been quoted $400 for the bloke to come here and remove, test, replace gastank as well as the rego gas compliance certificate.
What should I be looking for with regards to the converter playing up?
Shane
FollowupID: 534438
Follow Up By: Allan F (Gold Coast) - Tuesday, Nov 13, 2007 at 08:11
$400 sounds pretty good. Check the converter for coolant leaks and corrosion. Also check for a black stain around the diaphragms. The converters can also gum up inside due to tar like substance that the gas deposits. More often it is more economic to replace the converter rather than repair.
Cheers Allan
FollowupID: 534444
Follow Up By: Member - Shane D (QLD) - Tuesday, Nov 13, 2007 at 09:07
Thank again Alan
FollowupID: 534453
Reply By: Peter k (NT) - Monday, Nov 12, 2007 at 14:54
IN the NT you can't get your vehicle registered each year without a gas inspection as well as a vehicle inspection. I had the 10 year gas inspection and a gas tune up on my Landrover discovery last year and that was around $900. They do take the cylinder out and I think the price was going to be around $600 for the inspection if nothing else had to be replaced.
Peter.
AnswerID: 271370
Reply By: Mr Fawlty - Monday, Nov 12, 2007 at 19:35
In the ACT gas installations have to be done yearly and cost around $200 extra. This also includes gas installations in Motor homes, caravans etc used for cooking but it is rarely policed, I only discovered that it was required when my Van was inspected at a roadside rego check. I pleaded ignorance and said that at no place on the rego renewal does it state that the gas installation has to be checked prior to registration...I had to get a licenced gasfitter to inspect it ($387) and send the certificate to the comptroller of motor vehicles. Not before scanning it into my PC so that I would have something to photoshop for next time......
The ACT Beauracracy has too much time on their hands me thinks...
AnswerID: 271399
Follow Up By: Member - Shane D (QLD) - Monday, Nov 12, 2007 at 22:21
If I'm reading this right, the ACT system say's that vehicles using gas have be inspected every year, and also if you have a gas appliance in your vehicle, you have pay $200 every year for an inspection
So much for cleaner and greener.
Shane
FollowupID: 534396
Follow Up By: Mike Harding - Tuesday, Nov 13, 2007 at 07:04
Fawlty! You're a _bad_ boy - damn good idea though :)
Mike Harding
FollowupID: 534433
