caravan jack
Submitted: Monday, Nov 12, 2007 at 17:27
ThreadID: 51528 Views:2166 Replies:2 FollowUps:1
My dad has just bought a caravan, about 15 years old. It didn't come with a jack, what sort would be the best? Van is about 17 foot.
Thanks Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: Member - Matt (Perth-WA) - Monday, Nov 12, 2007 at 17:52
Lyndon, from most auto retailers you can get a good quality bottle jack. You can find the caraven GVM on the complience plate to ascertain what size you need.
Having a guess its a tandem axle so divide the GVM by 4 and then leave a safety margin and you should be fine.
Just make sure there is a good, stable and flat lifting surface under the axle/wheel station.
What type of vehicle does he have? Ie is the vehicle one satisfactory at lifting...GVM of vehicle/4 and how does this compare to trailer. Would not go there is its a scissor jack but a factory bottle....
All the best
Matt.
AnswerID: 271385
Follow Up By: Notso - Monday, Nov 12, 2007 at 17:58
Also make sure it fits under the vehicle when the tyres are flat!
FollowupID: 534346
Reply By: Ray - Monday, Nov 12, 2007 at 19:02
You may need two jacks as some caravan wheels go up inside the guards when lifting and then you can't remove the wheels, so you may have to lift the chassis as well
AnswerID: 271393
