pajero gearbox
Submitted: Monday, Nov 12, 2007 at 20:15
nicandsteve
hi, i'm about to put a new clutch in my nh pajero,just wondering if anyone else has removed a gearbox from a nh and is it a big job or an easy job? thanks steve
Reply By: nowimnumberone - Tuesday, Nov 13, 2007 at 12:27
i did one last week for a customer.
very easy on a hoist dont know about on the ground.
it also might pay to pull the bell housing of and replace the seal at the front of the gearbox.
also if its a v6 theres a cpl of o rings on the back of the heads behind a plate held on with a cpl of 8mm bolts they have a habbit of leaking much easier to replace with the box out and have a good look at the rear main while the flywheel is getting machined.
apart from that its easy.
271466
Follow Up By: nicandsteve - Tuesday, Nov 13, 2007 at 19:58
box is nearly ready to come out do i have to take the gear sticks out or can i leave them in?
534553
Follow Up By: nowimnumberone - Wednesday, Nov 14, 2007 at 00:10
yes 4 bolts for gear stick and i think its3 for transfer lever and use a bit of silastic when you put them back on to seal them or they will leak oil
534612
