WTD: CODAN 9323 microphone lead with plug?
Submitted: Tuesday, Nov 13, 2007 at 15:07
ThreadID: 51559 Views:3835 Replies:3 FollowUps:2
My microphone lead for my CODAN 9323 is broken.
A checked the price. The lead plus the plug is about $140.
Anyone knows where to get cheaper spare parts for Codan 9323?
Guy
Reply By: Member - John T (NSW) - Tuesday, Nov 13, 2007 at 16:50
G'day Guy
Not sure if this Ebay gent can help but he has Codan stuff regularly.
His ebay tag is unkerdunk - he phone number is below
David on 0408345208
Good Luck
John T (Lifetime Member)
VKS-737 Mobile 2619
Selcall 2619
AnswerID: 271514
Follow Up By: Member - Guy N (QLD) - Monday, Nov 19, 2007 at 10:49
Thanks John for the contact.
I had a Very nice with David.
Guy
FollowupID: 535740
Reply By: jdwynn (SA) - Tuesday, Nov 13, 2007 at 20:49
Guy
I had to replace mine as well. It was also $140.
I also had the 'insert' go in the microphone on a trip, and had to replace that ($25).
Hence I think the mic/lead is the most vulnerable item about the 9323. So IMHO, like me, I think you should look for a spare mic and lead. Now I always carry 2.
New they cost around $300. Not sure if Codan supply it but perhaps check out Jenal if you want new Jenal.
On ebay they go for around $150 second hand. Few come up last 6 months though so could be worth more now.
good luck JD
AnswerID: 271571
Follow Up By: Member - Guy N (QLD) - Monday, Nov 19, 2007 at 10:52
Thanks for the interesting info, but Jenal is out of stock at present on the mike, cord + plug.
Guy
FollowupID: 535741
Reply By: wilko65 - Tuesday, Nov 13, 2007 at 21:09
Aboout 3 years ago I replaced 2 of my microphone lead due to the outer sheath of the lead perishing. What I done was found that the lead had the same amount of cores as some types of UHF microphone leads. From memory I think they are the ones with call buttons on the top. Doesn't really matter what brand.
I bought the microphones from a radio repair shop in Katherine N.T. I think they were about $30.00 each. I then cut the ends off the UHF leads and used that lead for the Codan leads. It is a rather fiddly job to do, but if you are handy with a soldering iron is quite easy. The length of the 2 leads is almost identical.
Just draw a picture of the original Codan wiring and make sure it ends up the same.
AnswerID: 271577
