Nissan Patrol GPS Antenna
Submitted: Tuesday, Nov 13, 2007 at 17:18
ThreadID: 51565 Views:3940 Replies:2 FollowUps:3
I have a 2007 ST-L Nissan Patrol which came with factory fitted Sat Nav. Does anyone know where the antenna for the GPS is located? The GPS used to work fine but now I only receive input from one or two satellites. I am just wondering if I have covered the antenna up with some of the extras I have installed.
Reply By: Louie the fly - Tuesday, Nov 13, 2007 at 18:49
Just a guess, is it in the centre of the dash near the windscreen? My Adventra (like Commodore) has the sensor for the auto headlights in that spot. I couldn't work out why my lights didn't work on auto. Then it came to me in two words. DASH MAT. Otherwise, contact your dealer P&A department.
Good luck.
AnswerID: 271539
Follow Up By: Montereykeys - Tuesday, Nov 13, 2007 at 20:35
I fear it may be under the centre of the dash. Unfortunately I have an aftermarket dash pod on top of the dash housing a uhf radio. But from memory the sat nav still worked fine after I installed the radio?
FollowupID: 534564
Reply By: Andrew-rodeo - Tuesday, Nov 13, 2007 at 19:40
A mate of mine has one and the aerial wasn't even pluged in. Just a small problem. Might want to get nissan to check that out.
AnswerID: 271551
Follow Up By: Montereykeys - Tuesday, Nov 13, 2007 at 20:32
The main GPS receiver assembly sits under the driver's seat. The antenna is plugged in but I can't follow where the wire goes to from there.
FollowupID: 534563
Follow Up By: Louie the fly - Sunday, Nov 18, 2007 at 21:25
did you get this sorted out?
FollowupID: 535663
