Fuel Economy towing the Camper trailer,what to expect
Submitted: Tuesday, Nov 13, 2007 at 21:00
GREENDOG
Well soon the Trak Shak is up and goin what kind of fuel economy would you be happy with towing it at 80 ks an hr the paj has had a full tune up and service,so lets base it on a 1/4 of a
tank to make things easy,for those that do'nt know the paj is a v6 petrol and the c/t weights in around 800kg,so what would you be happy with,how many ks would you like to get out of that 1/4 of a
tank to be happy with it all.cheer's GREENDOG
Reply By: QLD Kev - Tuesday, Nov 13, 2007 at 21:04
GreenDog,
My Triton has a 3.0L V6 motor and I get around the 17-18L/100km out of it when towing my trailer
Cheers Kev
| Russell Coight:
271576
Follow Up By: GREENDOG - Tuesday, Nov 13, 2007 at 21:17
O.k thanks Kev,it's some thing to go on thanks mate.cheer's GREENDOG
534575
Reply By: Member - Uncle (NSW) - Tuesday, Nov 13, 2007 at 21:15
Hi Geendog,
we had an old 88 Paj V6, we kept the
services and oil up to it, but the old motor was a bit tired. We got between 20 to 22 ltr/ 100 towing our 900kg camper down the Hume to Victoria.
271579
Follow Up By: GREENDOG - Tuesday, Nov 13, 2007 at 21:22
Thanks mate,i sopose my question is how much is to much,
mine is a 91 nh with the motor bein done up weather that makes a difference or not? cheer's GREENDOG
534578
Reply By: Crackles - Tuesday, Nov 13, 2007 at 22:03
Fuel consumption is an individual thing that varies alot due to tyre type & size, if a roof rack is fitted, weight & type of trailer, head or tail wind, weight of assesories, load in the car, speed of travel, steepness of hills & of course how much people exagerate. (Not that anyone would ;-)
Simply load it up, go for a drive & that will give you an excellent indication of actual fuel used. What consumption should one be happy with??
Well that will vary I suppose as to how much money one makes :-))
Cheers Craig...............
271594
Reply By: 96 GXL 80 series - Wednesday, Nov 14, 2007 at 00:23
We towed an 8'x4'6" tandem trailer empty over a distance of 650klm and returned with 2 engines / 2 gearboxes and a complete diff assembly and got exactly the same fuel consumption both ways.
We have done the same trip several times empty (no trailer) and used very much the same amount of fuel, as we fill up at the same servo when doing that trip.
Even towing you do have down
hill runs where you are not accelerating and you do get better fuel consumption and the extra weight will push you further.
That to depends on wind catch area also, the bigger the frontal area the more drag.
It also depends on the driver and the way he uses the towing vehicle to pull.
Try and watch how many Lt's per 100klms you are getting and work around that.
Find the best average and you will get into a rhythm of smooth towing.
Don't get caught out on
long flat roads and think you are slowing and put your foot down just to waiste fuel. This bring a lot un done.
271620
Follow Up By: 96 GXL 80 series - Wednesday, Nov 14, 2007 at 00:24
That was 650klms each way.
534613
Reply By: Member - Barnesy (SA) - Wednesday, Nov 14, 2007 at 02:50
There is a section on this exploroz site where people send in their fuel usage history on trips they have done. It's interesting, have a look at it.
Not much of a guide but my empty 4.2 diesel GQ gets around 12l/100km cruising on 110. With a fully loaded car, roof rack, trailer, fuel and
water cruising at 90 in 38 degrees i get around 16-17l/100km.
Barnesy
271626
Reply By: Member - Alastair D (NSW) - Wednesday, Nov 14, 2007 at 07:54
Greendog,
Until recently we had a 93 NJ Pajero 3L V6 and regularly towed things including a CT of about the same weight as yours.
With me driving and not pushing hard we would get around 13 - 14 l/100k w/o trailer and 17 - 18 l/100k with trailer on. If I pushed it or the wife was driving you can add 2 - 3 l to the above figures. These figures varied little over many trips and years. Typically travelled ~90k/h when trailer on.
Now have a 4.2 TD 100 series and it hardly knows the trailers are there and get ~ 13l/100k.
Must update owner profile.
271637
Reply By: Robin Miller - Wednesday, Nov 14, 2007 at 10:35
Hi Greendog
While there are clearly many variables a good rule of thumb to start with these things is to consider fuel consumption varying with your weight.
So if you Paj is 2500kg trip ready and CT is 800kg then start with an assumption that fuel use will increase by 800/2500 or nearly a third.
I.E. similar to reply 6 from Alistair
Robin Miller
271659
Reply By: GREENDOG - Thursday, Nov 15, 2007 at 19:10
Thanks to all that replyed to my post as one said the only way to find out is to load her up and go for a drive,thanks to all .cheer's GREENDOG
271856
