Help needed to ID Campomatic Gas Struts
Submitted: Wednesday, Nov 14, 2007 at 16:15
ThreadID: 51598 Views:7052 Replies:7 FollowUps:1
The BIG struts to help lift the floor and tent of my 1997 Campomatic have died.
I have ID them as Stabilus "Lift-o-mat"and have found the size in the catalogue, but I am stumped by the Newtons pressure required.The printed label has disappeared.
I have called a Campomatic dealer, Gainsell, but they have the same problem with no help from Trak Shak..
I would appreciate it if anyone with a Campomatic regardless of year could have a look at the big strut. About half way down is a printed label. I do not know if there even is a number there but if there is, it would be very helpful.
Thanks in advance.
regards Philip A
Reply By: Axel [ the real one ] - Wednesday, Nov 14, 2007 at 16:38
Our Campomatic is 2001 built with chassis no 2001 , model designation RangerMk3 , bottom gas struts IE; the bigger longer ones , are marked as MDI E0420A F1:700n ,,,,, nothing else to bee seen , depends on 'how" your strus have died but most can be regassed by the mobile gas strut guys.
AnswerID: 271704
Reply By: tdv - Wednesday, Nov 14, 2007 at 17:28
Don't know if it helps but i just replaced them on an Aussie swag and the pressure was 700 newtons. Have fun compressing them to fit though! I used a rachet strap.
Tez
AnswerID: 271714
Reply By: Member - Oldplodder (QLD) - Wednesday, Nov 14, 2007 at 17:36
Gas struts are usually specified or ordered by the following info.
length closed
length open
load to carry
have a look at this site.
Aussie Gas Strut Company
AnswerID: 271716
Reply By: TD100 - Wednesday, Nov 14, 2007 at 19:15
Hi Phil,dont regas them,waste of money,ends up being dearer than buying newies as the regas just doesnt last,at a guess 700n would be pretty accurate to do that job and also as previously mentioned have fun compressing them!!cheers Paul
AnswerID: 271729
Reply By: Philip A - Wednesday, Nov 14, 2007 at 20:04
Wow, thanks for all the great replies.
I did I suppose the obvious thing and contacted the local strut guy.
Mine are dead as the shafts are rusted so a regas is out of the question.
He recommended 700newtons also, and is coming tomorrow with new struts.
So with your input I am now sure that 700Newtons is correct .
Regards and thanks again Philip A
AnswerID: 271742
Follow Up By: furph - Thursday, Nov 15, 2007 at 08:05
The struts are more likely to be specified as supporting a LOAD of 700 Newtons.
Where (ap.) 1kg.=9.8N the supported load would be 71kg./strut.
The PRESSURE inside the strut to achieve this is measured in kpa, which in simple terms is a metric equiv. of psi
FollowupID: 534830
Reply By: MEMBER - Darian (SA) - Wednesday, Nov 14, 2007 at 21:11
I have an 04 Campomatic - my struts are ok at present but I've met owners who have had several Campos and they reckon replacement is the go when they fail. One owner reported Trak Shak to be worthless for after sales follow up - I did contact them while away at one stage (suspension issue) and they did not return my call (their answering machine was on - someone told me it is always on, and they don't ring back - could this be true ?).
Anyway - if the fitment is special to Campos........I have been referred to a bloke called Bill Gates in QLD - possibly a former employee of the 'old' Campomatic company (pre - TS) - advice to me was that Bill can supply anything for the Campos........07 3807 0769 .... he's at Logan River Rd Beenleigh.
AnswerID: 271758
Reply By: rags - Wednesday, Nov 14, 2007 at 21:55
Try this supplier http://www.uesint.com/
thanks Russell
AnswerID: 271766
