battery date stamps
Submitted: Thursday, Nov 15, 2007 at 22:25
Eric Experience
I have a Delkor battery that has just failed in one of my tractors. It is a calcium 27h-710 it is stamped 2HR09 ,can anybody explain the date code. Thanks in anticipation. Eric
Reply By: Member - lyndon K (SA) - Friday, Nov 16, 2007 at 07:39
2 = second H = hand R = reject and i guess the 09 might mean it was meant to last nine minutes :) sorry,couldn't help myself :))
271958
Reply By: Member - Andrew (QLD) - Friday, Nov 16, 2007 at 08:01
A quote from
http://www.allpar.com/fix/batteries.html:
The code is a string of letters numbers, but all the real information you need is in the first two characters. Usually, the code starts with a letter that corresponds with the month--'A' for January through 'L' for December (some manufacturer's codes omit 'I'; for them, 'M' indicates December). The second character of the code is a numeral that stands for the year. Thus, a code starting 'A2' indicates that the battery was shipped in January 1992; 'B2' indicates February 1992, and so on. (Delco reverses the letter and the number; a Delco code starting with '2C' indicates the battery was shipped in March 1992.)
I would summise it to be August 2002.
271959
Follow Up By: Eric Experience - Friday, Nov 16, 2007 at 22:05
Thanks Andrew,
Looks like the extra few dollars the calcium cost was good value as this battery has a very hard life in a tractor that gets started one time each year and works non stop for about 3 days Eric.
535251
Reply By: Member - Mainey (wa) - Saturday, Nov 17, 2007 at 00:19
If I understand the 'question' the date code in question is "stamped" into the top of the battery @ the edge, by the supplier of the battery when its sold (or filled if wetcell) to give it a history and is only for warranty purposes.
The date code may vary, with individual 'stampers' ideas of correct procedures....
'2' could be 2002 or February ??
'09' could be September ??
'HR' is a Holden !
generally the actual day is not included only the week, month & year
272124
