Do Nissan wheels fall off ?
Submitted: Friday, Nov 16, 2007 at 10:51
ThreadID: 51665 Views:4535 Replies:13 FollowUps:14
There appears to be no references on EO but it has been bought to my attention from elsewhere that there has been some problems with some Patrols loosing the occasional wheel whilst travelling.
From what I understand it seems confined to alloy wheels. In screening Niss/Pat accessories I don't see that alloys are an optional extra so one assumes then that it's a problem with wheels.
Could be a major safety issue if you have alloys.
Anyone heard anything one way or the other ???
Reply By: Member - John (Vic) - Friday, Nov 16, 2007 at 10:59
Try an archive search its been posted quite often.
This was one post just recently Nissan losing wheels
AnswerID: 271990
Reply By: Rock Ape - Friday, Nov 16, 2007 at 11:31
Mate runs a vehicle hire company and said he has had a few fall off
can't remember which wheel but it is the same one every time
AnswerID: 271996
Reply By: Peter McG (Member, Melbourne) - Friday, Nov 16, 2007 at 11:55
Cocka
As John indicated in his reply there was a post a couple of weeks ago about recent incidents.
I mentioned in that Post my experience from last year. To read more go to posts 35665 and 34261 in the archive.
Yes it does appear to be fairly common and it does appear to be an alloy wheel problem.
I think (but have not heard anything definate from Nissan Australia despite repeated attempts) that Nissan Australia have told all dealers to make sure they use a torque wrench when changing wheels. The torque setting info is in the handbook - 100ft lb. My dealer certainly uses them now - they didn't before my wheel came adrift.
I now use steel wheels when on trips and always check torque settings.
I do think that Nissan Australia have a duty of care to ensure that all Patrol owners are aware of the importance of using a torque wrench and I think they should eb doing further testing on the alloy wheels and recalling them if required.
I have also made a report to DOTARS and recommend that other owners who have lost a wheel do the same. It will only be weight of numbers that enables DOTARS to put pressure on Nissan to take action.
If you need anymore info send a MM
AnswerID: 272003
Reply By: blown4by - Friday, Nov 16, 2007 at 12:42
If you keep the nuts tight and check them regularly as you would on any light truck operating in off-road conditions or not, then they should not "fall off".
AnswerID: 272011
Follow Up By: Member - Ed. C. (QLD) - Friday, Nov 16, 2007 at 13:45
Exactly!!!
Checkin' yer nuts regularly is the key issue here;-)
Confucius say.....
FollowupID: 535139
Reply By: Redeye - Friday, Nov 16, 2007 at 12:59
My back wheel fell off.
Redeye
AnswerID: 272016
Follow Up By: Member - Cocka - Friday, Nov 16, 2007 at 13:19
What kind and why ?? A bit of info would be great.
FollowupID: 535134
Follow Up By: Redeye - Friday, Nov 16, 2007 at 14:30
Sorry to be vague.
2000 GU.
a couple of wheel studs broken and some nuts very loose.
Have mag wheels.
Was doing 20Km/h at the time slowing for the traffic. Had been doing 100 + only moments before on the highway.
Suspect the nuts may not have been fully tightened.
Also on checking last week I noted that one front wheel nut (drivers side) was loose. I mean I did it up a few turns with my finger before applying the wheel wrench. Will be doing regular checks from now on.
Redeye
FollowupID: 535147
Reply By: gottabjoaken - Friday, Nov 16, 2007 at 13:48
Check the wheel nuts...
I have NEVER regularly checked the wheel nuts on any vehicle or trailer I have owned, driven or been driven in.
No-one of my acquaintance has done so either.
The only occasion when a wheel has fallen off was on an Austin A30 at 4.00 am after a full night working on it, when I know that I only put the nuts on finger tight and did not do that wheel with the wheel brace.
For ANYONE to say that regular checking of torque of wheel nuts is required is absolute NONSENSE.
You would be advocating regular dynamometer testing if the brakes next.
What we need is a Ralph Nader to sue the bollocks off of them.....
Ken
AnswerID: 272027
Follow Up By: Peter McG (Member, Melbourne) - Friday, Nov 16, 2007 at 15:17
Well said Ken!
It is important that owners who have had problems submit their case to DOTARS: http://dynamic.dotars.gov.au/recalls/NotifyUs.asp
Nissan may then be forced by DOTARS to take action.
FollowupID: 535154
Follow Up By: Member - Cocka - Friday, Nov 16, 2007 at 16:07
I also totally agree Ken. The suspect wheels should not have sold in the first place. We still haven't established who the manufacturers of the alloys are.
If they are after-market there could also be insurance issues involved.
FollowupID: 535164
Follow Up By: Himble - Friday, Nov 16, 2007 at 19:19
"For ANYONE to say that regular checking of torque of wheel nuts is required is absolute NONSENSE."
A bold statement Ken! It's NOT nonsense, depends on what YOU consider regular..
Whenever I refit my OEM alloys after removal on my Series III TD42T I torque them up to 100ft/lbs. AND I check them every month or so - 5 minutes for piece of mind? Priceless!!
BTW, I've had many vehicles of all sorts of persuasions (hehe..) over the 40+ years I've been driving (under ALL types of conditions/terrain etc.) and to date have not had one wheel come off. Call me lucky if you like, but I put it down to basic care & maint. which includes using the ubiquitous torque wrench!!
Your comment "You would be advocating regular dynamometer testing if the brakes next." is just piffle!!
Himble
FollowupID: 535197
Follow Up By: gottabjoaken - Friday, Nov 16, 2007 at 19:38
piffle... Himble.
Well I don't think so.
There are hundreds of safety requirements of our vehicles thta we take for granted, and never test.
Brakes was given as an obvious example. the steering wheel not coming off in your hands could be another.
The door not falling open as you go round a corner could be another.
How many times do you check that the window glass does not fall out if you lean on it?
No, I do not expect to have to check that the wheel does not fall off. Once it is put on properly, it should NEVER come loose under any circumstances. That is a fundamental given. That is what the manufacturers are RESPONSIBLE for.
Sue the b@$+@&%$ so they learn, because it is the only way they will. Prevailing on their good nature is a total waste of time - until one of the management's children dies from such an incident.
Ken
FollowupID: 535201
Follow Up By: Himble - Friday, Nov 16, 2007 at 21:00
"No, I do not expect to have to check that the wheel does not fall off. Once it is put on properly, it should NEVER come loose under any circumstances. That is a fundamental given. That is what the manufacturers are RESPONSIBLE for."
"Properly" being the operative word, Ken.
But I'm unsure whether these wheel problems have occurred AFTER...what I mean is that have these wheel failures occurred AFTER others (owners/d3ealers/etc) have removed them??
I agree 100% that if a wheel has come off as a result of manufacturers then that's a big issue.
FollowupID: 535223
Follow Up By: Member - Phil G (SA) - Saturday, Nov 17, 2007 at 00:57
I'm with Himble. My father tought me to check wheel nuts on trips - that was 30+ years ago. We teach it in 4wd clubs. Even the owners manual tells you to recheck them. They usually nip up a little more after a run. A couple of minutes well spent.
The Patrol wheel problem is a bit different though - theres a bit more to it than just slack owners :-)
FollowupID: 535299
Follow Up By: stocky - Saturday, Nov 17, 2007 at 23:30
ever noticed truckie's when there stopped walking around with a big mutha wheel brace? Guess what - their checking their wheel nuts!
Are you too slack as a consumer to do your part for road safety and properly maintain your vehicle including simple tasks like checking your wheel nuts?
I do it as part of normal vehicle checks - i guess that was drummed into me as part of my truck license - a walk-around of the vehicle with basic road worthiness checks EVERY time you do a trip. Not hard to do and may save lives!
let the flames begin!
FollowupID: 535479
Follow Up By: Truckster (Vic) - Sunday, Nov 18, 2007 at 16:27
No they arent. They are usually checking the tires to see if they are flat, notice them ever hitting the tire with the lever (which is usually just their strapping bar)? Never in the 8yrs I drove trailers checked trailer wheelnuts when hitching another trailer..
FollowupID: 535596
Follow Up By: stocky - Sunday, Nov 18, 2007 at 18:33
funny - i always thought the black bits where tyres and the wheel nuts where the hexagonal bits in the middle - hence you would be correct if their "checking their tyres" by "hitting" the hexagonal WHEEL NUTS with the wheel brace................
we live near a roadtrain break down yard - and i'm not blind - or stupid :-)
and I know the difference between a wheel brace and a strapping bar - coz I have used both regularly!
Stocky
FollowupID: 535618
Reply By: Member - JohnR (Vic)&Moses - Friday, Nov 16, 2007 at 15:14
Nick R carries a torque wrentch now, since le lost his left rear alloy wheel. Doesn't seem to happen if you give them correct torque or use steel wheels.
AnswerID: 272033
Follow Up By: Truckster (Vic) - Friday, Nov 16, 2007 at 17:18
simple solution - bleep off the crap alloys!
FollowupID: 535173
Follow Up By: Nick R (VIC) - Friday, Nov 16, 2007 at 21:21
Bruce, I was thinking someone might want to swap alloys with nearly buggered tyres for a set of steels with new tyres.
Instead of making the steels black like all you blokes do I'd go yellow. yellow wheels on a green vehicle kinda like a john deere!!!
The alloys have not given me a problem at all in the last 5 months. they go well in the garage, tyre wear is good in there too. Borrowed the steels from you know who and put some decent rubber on them.....
Nick
Carpe Cerevisi
FollowupID: 535231
Reply By: Member - Cocka - Friday, Nov 16, 2007 at 16:00
I just remembered an article I read elsewhere that may be of help to those who are alloyly challenged. Quote - " Hi there - I have also come across alloy wheels coming loose - the problem on mine is quite simple - the wheel nuts have a tapered shoulder and were designed for steel rims. The Alloys fitted were designed for nuts with a flat washer (shoulder) and the use of the wrong wheel nuts compresses the alloy stud hole and eventually work loose.
The second problem I came across on a mitsubishi pajero also related to alloy wheels coming off - after market alloys were fitted, but no one had looked carefully at the ridge running around the hub - this shoulder protruded and prevented the alloy rim from sitting hard against the hub. As a result, no matter how you tightened the wheel, with use the alloy wore on the ridge and then came loose. Solution - fit a machined spacer the same thickness of the ridge so the alloy rim seats against the hub across its full width. Hope this helps" K Jensen -
End of quotes.
AnswerID: 272038
Reply By: Member -Signman - Friday, Nov 16, 2007 at 16:38
From the Westprint Newsletter..
.I am a Tour operator and since
1999 have owned nine Nissan Patrols, still have three. All the vehicles have
done in excess of 300000 Kms before disposal. That is about 3million
kilometres. In that time I have lost or damaged three LHS rear wheels. Every one
was in my opinion operator error. Not checking the studs often enough, worn or
broken studs or dirt under the wheel when it has been replaced. They have always
got me home. I have lost both steel split rims and alloy after market wheels. As
for the other mob, I have never heard them admit to anything any way. Bill
Brinkworth, Outback Bush Adventures.
A 2005 Nissan, a hire vehicle from
Kalgoorlie was stranded at Warakurna Roadhouse when we called there last
week, having lost a mag wheel.
Another problem worth
discussing is Toyota Landcruisers and troopcarriers cracking diffs. One gave
way on the Great Central Road last week and another troopcarrier
passed through this morning with its rear wheel at an acute angle on the
back of a truck. Two months ago rear diffs on two Landcruisers failed
between Uluru and Docker River. This is at a time when the road is at its best
condition in years. David.
I was working as a police officer
in Birdsville in July 2005 when the front passenger wheel came of a Nissan
patrol (alloy wheels again). This occurred about 90 km north of Birdsville
on the road to Bedourie. The tyre had been changed in Birdsville
earlier that day by the driver. The driver was a medical technician who
claimed to have tightened the nuts as far as he felt could have been done
without over doing it. As he was travelling around to all isolated
ambulances in Western Queensland to check their gear over and make any repairs,
I figured he knew a bit about tightening nuts and bolts.
The result was the vehicle rolled with two passengers on board who walked away
stiff, sore and very shaken but otherwise unscathed. The vehicle of course
was a write off.
The mechanics at the Diamantina Shire Council (in Bedourie) said they knew of
several similar incidents (prior to this crash) - all alloy wheeled
Patrols. It would appear to be a problem that has been going on for longer than
the last 12 - 18 months. Ross
As promised, I report the
members of the Nissan 4wd club of Victoria have suffered wheel stud failures in
many cases but predominantly with alloy wheels. There seems to be no known
reason for it even torquing to the required pressure. Alan. Nissan 4wd club Vic.
AnswerID: 272046
Reply By: Truckster (Vic) - Friday, Nov 16, 2007 at 17:19
DDR had one fall off few weeks ago infront of me around Murray Sunset.. changed the day before, snapped stud, all other nuts loose..
AnswerID: 272053
Reply By: Wheatbelt Wayne - Friday, Nov 16, 2007 at 19:15
Mine are steel wheels (Nissan Originals) and I had one come right off after shearing all 6 studs on the drivers side rear. Luckily (if you want to look at it that way) I was crossing a dry creek bed and the hub fell into the sand. Lots of dirt etc in and around the brakes, but was easily cleaned out. Only problem was I was about 60 km from Marble Bar on a remote and unused track.
Mate stayed with me whilst the other half and her mum drove into "the bar" in mates car and sourced some second hand ones. Good service from some local aboriginal people who offered to follow them out to make sure all was OK. Same aboriginal fellow checked up on the other half the following week when he was in Port Hedland Hospital, to make sure she had returned!! Also the local wrecker helped out to make sure the sourced studs were the same diameter as the old ones.
An hour of jacking and packing with rocks and logs and we were on our way. Those studs are still on there today!
So it's not just the alloy ones that have these problems. Now I've got to get around the steel ones and the cracks in the spokes.
Wayne
AnswerID: 272070
Wayne
AnswerID: 272071
Reply By: gottabjoaken - Friday, Nov 16, 2007 at 19:43
Well, what are all you entrepreneurial lawers waiting for.
where is the class action????
For 50% of the compensation, you could make a killing...
Ken
AnswerID: 272074
