very slow filling water tankson jayco.
Submitted: Saturday, Nov 17, 2007 at 17:18
briggzee (WA)
We have a jayco dove offroad camper with 2
water tanks. It is very frustrating to fill as the inlet to the tanks are on the bottom of the
tank. Is this normal? I have removed one
tank in an attempt to turn it the other way up but it will mean that there is no drain point, also the outlet sits up about 50mm from the (new) bottom. Any suggestions or ideas would be greatly appreciated. Thanks, Craig
Reply By: Member - Kim M (VIC) - Saturday, Nov 17, 2007 at 17:28
briggzee
I think you have a problem. I've never heard of this sort of installation on any camper van.
Might be a good idea to ring Jayco.....something does'nt sound right.
Kim
272208
Reply By: disco driver - Saturday, Nov 17, 2007 at 18:03
Briggzee,
From my experience the caravans and campers that I have owned are relatively slow to fill.
Inlets on the bottom of the side of the
tank are reasonably common and most are around 25-30mm diameter.
A few things to check out.
1.Are the breather/overflow outlets blocked. These are usually on top of the
tank and dribble when the
tank is full.
Do the tanks have breathers lines fitted. Probably not.
I made up my own using PVC trickle fittings, plastic hose and high grade sikaflex (not any old silicone ) I used a Ryco universal fuel filter at the open end to keep out bugs, dust etc.
These help to speed things up but the tanks have to come out to fit them. They are 12.5mm plastic hose and have a filter of some sort on the open end. This end must be fixed at least 150mm above the top of the
tank
2. What size filler hose is fitted and what diameter
tank inlet, the
tank inlet is the limiting factor.
Anything under 25mm will be slow
Not much else I can suggest
Disco.
272210
Follow Up By: disco driver - Saturday, Nov 17, 2007 at 18:04
Ryco filter is the plastic in-line variety.
Disco.
535384
Follow Up By: briggzee (WA) - Saturday, Nov 17, 2007 at 18:14
Disco, the filler hose is approx 25mm and the tanks do have a breather line fitted which goes up and finishes next to where the filler hose is. I have spent a bit of time straightening out the breather hose to try and avoid
water blockages. The filler hose on the bottom doesnt seem to make sense as the incoming
water has to "push" up the
water in the
tank? I cant see any other way so I'll have to perservere and hope that the tanks are full. Thanks
Craig
535386
Follow Up By: Member - Kim M (VIC) - Saturday, Nov 17, 2007 at 19:21
Craig
It's a bit hard to picture what's going on, but try this.
Disconnect the nozzle off the garden hose and place the hose at least 100mm below the breather then fill the
tank.
Let us know how you get on.
Kim
535407
Follow Up By: 96 GXL 80 series - Saturday, Nov 17, 2007 at 19:45
Briggzee,
not sure if it will help but is worth a try.
Disconnect the power to the pump and leave the tap turned on and this might let the air pressure out of the
tank while filling.
535414
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Nov 17, 2007 at 20:50
Hi Craig
I never fill my twin tanks from the filler cap.
I have fitted valves between them on both inlet and outlet so I can use them one at at time. This also prevents you loosing all your
water if one gets a leak.
I pressure fill my tanks one a a time from the drain tap until the
water starts flowing from the over flow. This way I get 2 full tanks with no air lock.
Derek.
272233
Follow Up By: Member - Poppy (QLD) - Sunday, Nov 18, 2007 at 19:21
Hi Derek
I have same prob as Craig so will try your tip
But I also cannot get rid of plastic taste in the
water and I use a food grade hose and have flushed both tanks several times with bi carbonate soda after letting it soak for a few days but still the bad taste, any suggestions?
Cheers Ray
535632
Reply By: Member - Charlie M (SA) - Sunday, Nov 18, 2007 at 22:33
briggzee
It is possible that the vent lines going back up to the filler have a slight bend in them and are filled with
water that will give a restriction for filling. Have two tanks on my caravan and one fill point have both bleeds hooked together and have no problems filling tanks. Both tanks inlets are pipes halfway up
tank. Breather lines are dripper tube have dripper filter to stop bugs ect entering system.
Chass
272425
Follow Up By: Member - Graham H (QLD) - Tuesday, Nov 20, 2007 at 19:38
Or they could be like
mine were and have a kink in the filler tube.
Only found it when putting a hatch in the side of the van. One tube was virtually blocked and that
tank was actually gravity filling off the second one. Might be worth a look at the pipes if you can see all of them.
536072
