ENGEL cooling on 240 volt but not on 12
Submitted: Saturday, Nov 17, 2007 at 20:15
ThreadID: 51714 Views:4266 Replies:4 FollowUps:5
If any one has read my last post you'll know what i'm talking about, so tell me i must be up for a new deep cycle battery going on my replys.cheer's GREENDOG
Reply By: QLD Kev & Darkie - Saturday, Nov 17, 2007 at 20:17
Greendog,
Check the plug/lead it may need replacing as it is a common fault with the Engels
Cheers Kev
PS charge the battery :))
Russell Coight:
AnswerID: 272229
Follow Up By: 96 GXL 80 series - Saturday, Nov 17, 2007 at 20:33
Must have been off for along time to turn a Dog into a "GREENDOG"
If you have it connected via a fuse line check the fuse as well.
Give the ends of the fuse a check with a multi meter just in case.
FollowupID: 535431
Follow Up By: GREENDOG - Saturday, Nov 17, 2007 at 20:34
Kev i have played around with the lead and it seem's o.k as i have power all the time it just stopped getting cold,the deep cycle is about 3 yrs old and has done abit of work.cheer's GREENDOG
FollowupID: 535432
Follow Up By: GREENDOG - Saturday, Nov 17, 2007 at 20:40
It's a Piranha set up so i'll try and get hold of a meter to test the battery
FollowupID: 535435
Follow Up By: chris007 - Saturday, Nov 17, 2007 at 23:26
Hi Greendog,
I have just been in the NT for the last month (bloooody hot 24 hrs a day) and my engel 40L was not performing as well as it did on the east coast. I visted an engel service agent in Darwin and he certainly knew his stuff. Here are my suggestions.
1) Defrost it first (just to eliminate this from the possible problems).
2) Charge your battery with a charger as suggested above.
3) If it is working on 240V but not 12V my bet is it is not getting enough current. As I found out - even though you might read 12.5V at the battery terminals and the fridge plug - you need to load test it. I used an 8amp load tester and it dropped to 10.5V which indicated a problem such as inadequate guage wiring, faulty plug etc (in my case a loose connection). The actual engel plug is far more robust than a cig plug.
The point above is that you need to test it under load - if you are handy with electronics, just grab a decent resistor and use it inline before the multimeter, or most engel service agents shoud be able to do a load test for you in about 30seconds.
You can also go to most auto stores or mechanics and they can load test your battery (just bear in mind they are testing high load cranking power - not what your fridge needs).
Hope this helps.
Chris.
FollowupID: 535478
Follow Up By: Member - Davoe (Yalgoo) - Sunday, Nov 18, 2007 at 08:38
"The actual engel plug is far more robust than a cig plug."
- No it aint Mine doesnt make a good connection and sometimes just goes dead. Just a bit of a play with the plug gets it going again. problem seems to be in the conection between the male and female plug. I suspect this to be the cause of marginal performance of the fridge on warm days
FollowupID: 535516
Reply By: the mightyQ - Saturday, Nov 17, 2007 at 23:16
G'day Greendog,
Yeah! I have had the same trouble, checked leads, fuses and battery connections & battery. Turned out to be the fan, bought a new one and has worked well ever since, just going on 3 years .
By the way Dick. S's has them for a fraction of the cost from memory they are a 80 - 90mm
Good luck
andy
AnswerID: 272244
Reply By: QLD Kev & Darkie - Sunday, Nov 18, 2007 at 09:32
Greendog,
If you need a new 12v lead let me know I have a brand new one spare (I have 3 in total) and I'll send it to you.
Cheers Kev
Russell Coight:
AnswerID: 272283
Reply By: GREENDOG - Sunday, Nov 18, 2007 at 19:56
Thanks to every one that replyed and are trying to help i'll get the electrian at work to put he's meter on the batt tomorrow i'll keep you posted.cheer's GREENDOG
AnswerID: 272371
