Poly air bags
Submitted: Sunday, Nov 18, 2007 at 10:44
ThreadID: 51729 Views:4158 Replies:7 FollowUps:5
I have a 'moderately' loaded troopy with tow bar . The suspension is stock standard and just 50,000km old. When travelling through serious washouts the rear wants to drag. I thought polyair black bags on the rear would give the extra clearance and all would be solved at low cost. But alas - I read another thread which noted that airbags reduce wheel travel!
What's the go for remote travel in troopy - never towing
Chris
Reply By: Dave B (NSW) - Sunday, Nov 18, 2007 at 11:10
Chris, I posted the other thread about the airbags, and my reasons for thinking along those lines was to level up the car when I have the CT on.
I wasn't too interested in lifting the back higher than normal, I think you would have to go to different springs for that. IMHO
Also, I was thinking Boss airbags, not Polyairs.
'Wouldn't be dead for quids'
AnswerID: 272302
Reply By: Andrew(WA) - Sunday, Nov 18, 2007 at 11:19
Chris
I've had Poly Air bags in a few cars. Most recently a GU Patrol. The Air bags lifted the back of Patrol considerably...maybe inch and half or more, never actually measured it...and I thoroughly recommend them.
As long as you don't 'overweight' the tow ball, the Poly Air bags will level the ride nicely and stop any bottoming out.
I've just bought a new (2nd hand) 100series and that has bags in it already. If it didn't, it would be one of the 1st things I would consider putting in.
I having nothing to do with the Poly Air bag Company in any way. In fact I hear others are just a good.
Good luck.
AnswerID: 272303
Reply By: Peter 2 - Sunday, Nov 18, 2007 at 12:53
Airbags are never very successful on a leaf sprung vehicle unless it is a street queen and only ever used on the bitumen.
They limit suspension travel, can give a choppy ride and will as the spring moves back in compression twist the bag sideways between the top and bottom mounts, much better off to change the springs to suit the load you are carrying.
An extra leaf in the 3rd from the top position, cold reset of your existing spring leaves to match the new leaf and refitting with genuine Toyota rubbers is the best, most durable and cheapest solution I found after owning and using four troopies over 25 years.
AnswerID: 272318
Follow Up By: Steve from Top End Explorer Tours - Monday, Nov 19, 2007 at 10:10
I agree 100 %, owned and driven many troopies over a similar period.
Cheers Steve.
FollowupID: 535733
Reply By: Member - Phil G (SA) - Sunday, Nov 18, 2007 at 20:25
Chris,
I bought a set of the Boss airbags for the leaf sprung 78/79series.
Did some measurements, which confirm what others say above about suspension travel:
On compression, you'll lose at least 70mm. The standard bump stop is 100mm long. The airbags will compress down to 170mm.
When extended, the airbags will stretch to the full length of the factory shocks. But my Old Man Emu shocks have an extra 40mm, so I'll lose that.
But the bags are twin bellows - look very strong and the quality of the bags looks very good. I have no doubt that they will prop up a sagging rear end, and maybe stop some of the sway when you've got a load on board, and make life easier for the leaf springs.
I'll go ahead and fit them and see how they go, but I'm not keen on limiting the articulation. For the heavy loads on the desert tripsl, I think they'll be OK.
AnswerID: 272389
Follow Up By: Dave B (NSW) - Sunday, Nov 18, 2007 at 22:00
Phil, interesting what you say about the suspension travel, but maybe the extra leaf in the spring would also cut the suspension travel down a bit too.
I guess you have to weigh up the pros and cons of how many times do you need maximum articulation against the times you need the load levelling capabilities of the airbags.
I will measure the travel on my 61 tomorrow now that you have mentioned the figures.
FollowupID: 535684
Follow Up By: Member - Phil G (SA) - Monday, Nov 19, 2007 at 14:55
Dave,
Extra leaf won't affect travel - travel is limited by bumpstop and shock length.
There might be a different airbag for the 60series, and the springs in the 60series are a fair bit shorter than those in the 79series, so I'd expect figures to be different.
FollowupID: 535774
Follow Up By: Member - Pesty (SA) - Monday, Nov 19, 2007 at 16:41
Chris,
I fitted coil springs to my 60, and have had a great run from them.
They didnt affect the articulation at all, that was limited by shockers and the the bump blocks.
I have just fitted a new set after 250,000 very hard ks.
They are very popular with farmers and roo shooters.
To quote my wife on our first loaded camping trip with them on,
"she tides like a limo"
Well it rides good for a leaf 4by anyway LOL
Cost around $350, so not too expensive.
Cheers pesty
FollowupID: 535802
Reply By: Ray - Monday, Nov 19, 2007 at 10:00
Has any body had any experience with the AirLift 1000 air bags from the U.S.?
AnswerID: 272472
Reply By: Member - Alex K (NSW) - Monday, Nov 19, 2007 at 11:43
I read a lot about limiting suspension travel in leaf sprung rear ends, I assume the same would apply for springs? What is the minimum air pressure you can put in the bags? I am thinking that if you really need all your available wheel travel and not have it limited by the air bags, could you not simply deflate them?
Comments?
AnswerID: 272492
Follow Up By: Member - Phil G (SA) - Monday, Nov 19, 2007 at 14:51
Alex,
The numbers I gave above on compression were with the bags fully deflated.
FollowupID: 535772
Reply By: Member - Oldbaz. NSW. - Monday, Nov 19, 2007 at 17:53
I tried Polyairs a few years back on the Hilux Sprayrig, apart from getting holed regularly, they bottomed out something awful.
Cured by getting uprated rear springs at not much cost difference
to polyairs fitted. Go to a spring manufacturer, not Toyota or
the 4WD Candy Stores......oldbaz.
AnswerID: 272561
