GQ Patrol body lift
Submitted: Sunday, Nov 18, 2007 at 21:21
ThreadID: 51754 Views:3597 Replies:2 FollowUps:2
G'day guys iv bought a 2"body lift off ebay and im wonderin the best way to lift the body from the chassis, I dont have a big jack nor have anywhere to use a high lift (alloy bull and rear bars) any ideas?
Reply By: Member - Littleborgy (SA) - Monday, Nov 19, 2007 at 18:26
Hi Greg,
Just had a look under my GQ & there's a bit of a gap between the chassis & body already (no lift).
Just get a nice thick piece of wood, cut one end into a "wedge" shape & bang it in there with a hammer until there's enough room to fit your lift kit, fit the lift, then pull the wood out... Repeat at each mounting point... Should work like a charm.
Hope this helps
Cheers, Brad
AnswerID: 272569
Follow Up By: Gregs GQ - Monday, Nov 19, 2007 at 18:58
yeah that could work, I was thinking maybe a forklift with some timber on the tines......
FollowupID: 535844
Reply By: Truckster (Vic) - Monday, Nov 19, 2007 at 21:55
Buy a cheap Trolley jack and if need be, a large block fo wood on that, then put it under the body.. 1 side at a time.. then shove car stands under each side as you go. just loosen everything before jacking.. instructiosn on www.gqpatrol.com are easiest
done several of these setups now with compressor and rattle gun, last time we replaced body mount rubbers, we did it in 2 hours with 2 people doing it. (LWB)
Intersting to note, most people I know are removing their body mounts these days, puts loads of stress on the sheet tin floor pan and if your body mount rubbers are shagged can rip the floor.
AnswerID: 272621
Follow Up By: Voxson - Tuesday, Nov 20, 2007 at 13:54
Your two rear mount nuts can be really hard to undo. They are sposed to be captive but they break away and start to spin.
Be prepared for a little floor surgery maybe.
FollowupID: 536002
