Loose nuts
Submitted: Monday, Nov 19, 2007 at 10:56
Lawrence
I seem to be having a problem with my wheel lugs, especially some closed ones. They seem to keep loosening. What could be the problem?
Reply By: KSV. - Monday, Nov 19, 2007 at 11:11
What wheel do you have?
272482
Reply By: Member - Kiwi Kia - Monday, Nov 19, 2007 at 11:13
Do you have alloy or steel rims ?
Do you know that there are different types of nuts used on each of these wheel rims.
272483
Reply By: Lawrence - Monday, Nov 19, 2007 at 11:16
US steel
wheels. One thing also is that the lugs seem shorter compared to the OEM
wheels.
272484
Reply By: KSV. - Monday, Nov 19, 2007 at 11:20
And nuts - where they come from? I am trying to say the same what Kiwi - there are differenet nuts for different rims. Try standard "open" nuts and see if you have a difference.
272485
Reply By: Member - Doug T (FNQ) - Monday, Nov 19, 2007 at 11:26
Lawrence
It could be that the closed ended nuts are not allowing
the nut to screw fully on and is coming up onto the stud end, especially if the
wheels are not standard, get a set of open nuts . \I think K.S.V might be heading the right way too,
Doug
272489
Follow Up By: KSV. - Monday, Nov 19, 2007 at 11:31
I thought about this, Doug, but he says that they get loosed, and he did not said that he cannot tide them properly.
Serg
535746
Reply By: Member - Lionel A (WA) - Monday, Nov 19, 2007 at 14:12
Lawrence,
Maybe a wrong choice of title to your thread.
Try a pair of Jockey Y-Fronts.......LOL.
Cheers.....Lionel.
272515
Reply By: Member - John (Vic) - Monday, Nov 19, 2007 at 14:17
What make/model vehicle??
Just wondering if this is a further Nissan wheel nut issue??
272518
Reply By: Lawrence - Monday, Nov 19, 2007 at 14:29
Yes, Doug T. I agree with what you said about the closed lugs not tightening properly because of their length. They are almost twice as long as the open lugs. I will get some more of the open lugs to replace them tomorrow. Thanks for all the responses
272523
Reply By: Lawrence - Monday, Nov 19, 2007 at 14:31
Nissan Patrol gq. Open end nuts fit perfectly (even though further out on the studs than with the oem
wheels), so dont think its a Nissan issue.
272524
Reply By: Member - Kiwi Kia - Monday, Nov 19, 2007 at 14:45
Just to be sure !
Can you recognise the differance between nuts for an alloy rim and a steel rim ?
Alloy wheel nuts are stepped with a flat collar like a big washer on the wheel end.
Steel rim nuts are tapered (cone) shape at the wheel end.
272527
Follow Up By: Lawrence - Monday, Nov 19, 2007 at 14:47
I will have a look in the morning to make sure
535770
Reply By: Lawrence - Thursday, Nov 22, 2007 at 13:59
My mechanic tightened them and not a peep since, except for the back which was making an awful racket. Turns out that the back wheels werent sitting properly since they were a tad bit too small for the centre piece on the drum (108 mm centre). To make it worse I had put on the centre piece that came with the wheels, which helped make the racket. So I am going to machine out the centres to 112 as per the oem wheels.
273118
