Repairing tubes
Submitted: Monday, Nov 19, 2007 at 18:44
Member - Shane D (QLD)
I put on a patch about 2 months ago, to repair an inner tube, for the first time, and up until the weekend, held.
On Sunday I bit the bullet and attempted to fix the tyre that was going flat only to find that it was leaking out from under the patch, so, I got another bigger patch and refitted ensuring no grit got in there, that lasted 'till lunch time.
Question is, How are you SUPPOSED to put on a patch?
I'm thinking I'm doing something wrong,to have 2 out of 2 failures seem's rather indicative, I hope my children don't suffer the same fate!
Shane
Reply By: Member - Davoe (Yalgoo) - Monday, Nov 19, 2007 at 18:48
It is almost vertainly one of the cheap tubes that come from a box with tyres R us on it.
the rubber these things are made of just doesnt 'vulcanise" the patches or something and it isnt just you and me I watched an old bushey who had done xxx amount of repairs get driven to despair trying to get a patch to stick
you dont repair them you terf em
if you want to repair them get a name brand tube - michelin, bridgestone etc
272571
Follow Up By: Member - Shane D (QLD) - Monday, Nov 19, 2007 at 20:28
Thanks Davoe,
I don't know what brand of tube they are but when I bought 2 spares later from the same place, they where Firestone tubes
535856
Reply By: Mikee5 (Logan QLD) - Monday, Nov 19, 2007 at 19:38
Hi Shane,
The secret is to really rough up the surface of the tube. Your kit should have included a roughener like a rasp. One roughed up, clean the tube with solvent or at least
water. When dry put the glue onto the inner tube, let it dry. Peel the lining off the patch at this stage, put the patch onto the tube and press it on very hard, your kit should have a roller in it for this. Finally dust some chalk onto the repair (fine dust will do) to stop the edges of the glue sticking to the inside of the tyre. This is my method and it usually works. Hope it helps.
272579
Follow Up By: Member - Shane D (QLD) - Monday, Nov 19, 2007 at 20:26
Thanks Mike,
Two things I did wrong.
I didn't let the glue dry, I noticed this when I stripped it today,The patch appeared to stiick to the tyre as
And the dust trick.
Every thing else I did, and maybe A little too much glue.
When you refer too the patch liner, do you mean the alfoil side or the clear plastic side?
Shane
535854
Reply By: MEMBER - Darian (SA) - Monday, Nov 19, 2007 at 20:46
I've been a cyclist for along time and used to have the same problem you seem to have on your mota - I picked up a great tip years back from an 'old hand' that turned it round for me. Lightly roughen the area concerned on the tube with sandpaper - get the puncture area level and apply a liberal glupe of the adhesve cement (about the same size as the patch) - let the cement soak into the rubber for about 10 minutes - do it again - for the third time, apply a thinner glupe of cement and the patch - clamp it with light pressure and leave for some hours to cure. We cyclists used to have a number of tubes with us - repairs were done home in the shed when required, so curing time was not a problem - done properly, the repair area is probably tougher than the original tube.
272596
Follow Up By: Member - Shane D (QLD) - Monday, Nov 19, 2007 at 22:18
Thanks Darian,
I replaced the whole tube today, but still, would like to be equiped with the proper knowledge on how to use the glue, and fix it right, once.
Shane
535887
Reply By: Peter 2 - Monday, Nov 19, 2007 at 21:24
Rather than physically roughening the tube I use a Rema product
called "Liquid Buffer" which cleans the tube. I've also used acetone and unleaded petrol to achieve the same result.
As has been said chalk or fine bulldust over the repair to stop it sticking to the tyre.
The tubes branded Mr Tubes are rubbish as are ones with ablue line around them won't vulcanise and the Mr tubes ones get pinholes or split at the seams.
Stick to brand names like Michelin, dunlop etc.
272609
Follow Up By: Member - Shane D (QLD) - Monday, Nov 19, 2007 at 22:12
How do you use the "buffer"?
Do you put it on wait for something to happen.
Shane
535881
Follow Up By: Peter 2 - Monday, Nov 19, 2007 at 22:30
just wipe it on with a clean rag which instantly goes black, the wiped area of the tube goes a flat black and dries virtually instantly. Then you put the vulcanising liquid on and after it has tacked off put the patch on.
535891
Reply By: Go-N-Grey (WA) - Monday, Nov 19, 2007 at 21:56
Is it possible to buy the old style vulcaniser patches and clamp.
5 minutes, a bit of smoke and a real cool smell of saltpetre and it never leaked again.
I've never trusted glue, and I believe that is still true....
In the Kimberlies in the 60's, Roadtrak Majors, canvas top Series IIA landrovers, a Menzel pump, and a vulcaniser kit were life saving essentials
272622
Follow Up By: Member - Shane D (QLD) - Monday, Nov 19, 2007 at 22:15
I haven't seen them in years, and I also never had one those fail, I'd far prefer vulcanised patches.
Shane
535883
Follow Up By: Member - Dick (Int) - Tuesday, Nov 20, 2007 at 02:10
"In the Kimberlies in the 60's, Roadtrak Majors, canvas top Series IIA landrovers, a Menzel pump, and a vulcaniser kit were life saving essentials"
So true, now people don't leave home without 200kg of accessories, and 200kg of other equipment. Makes you wonder how we managed to get around in those days.
535919
Reply By: Mikee5 (Logan QLD) - Wednesday, Nov 21, 2007 at 18:52
Hi Shane,
Sorry to leave the reply so late - had to work!!!
Leave the alfoil side on until you are ready to put the patch on. (This is just to keep it clean). Leave the plastic side on until you have rolled the patch on. The plastic has a split down the centre, just bend the tube to split it more and pull from the centre outwards.
272988
