Small washing machine.
Submitted: Monday, Nov 19, 2007 at 19:42
Member - Charlie (WA)
Hi all, this is slightly O/T but I thought it may be something the caravaners out there may be able to help me with.
Mother dearest is looking for an new front loading washing machine for her house, so must be 240v. Size is the problem, she wants to fit it inside her laundry cupboard so needs to no bigger than the following. Depth - 530mm x Width - 550mm x Height - 820mm, also needs to take a load big enough to fit a queen size doona cover.
It appears that none of the usual manufactures make a machine this small so I thought there may be something that is made for caravans or motorhomes.
Ta, Charlie
Reply By: Member Boroma 604 - Monday, Nov 19, 2007 at 22:34
Gooday,
Try looking at Lemair,Top Loader, or Dometic, front loader.
Lots of people fit them in their Caravans.
You will probably get a Q size Doona into it, but I don't know if it will be big enough to Bath it.
Will possibly have to look at Caravan accessory supplier like Camec, or try a look on the Internet first, also put a Wanted to Buy advert in Caravners
Forum or Touring Oz Forums.
272636
Reply By: Member -Dodger - Tuesday, Nov 20, 2007 at 16:59
Lemair make a small one that is used in caravans and it should suit your needs and they are 240v.
272745
Reply By: gottabjoaken - Tuesday, Nov 20, 2007 at 17:12
try this link
Not sure if Dometic still marketing this, but you can find out.
Looks within your size requirements, and will do a 3kg load, but do not know if a Queen size Doona Cover will fit in there.
Dometic WMD1050 leaflet
272747
