Campervan Fridge - Gas/Electric or Just Electric?
Submitted: Tuesday, Nov 20, 2007 at 21:44
SimonInAustralia
I am going to buy a Landcruiser Bushcamper 4WD campervan soon.
It will most probably come with a chest style fridge, which I will want to upgrade to a larger upright style fridge.
Should I consider a gas/electric fridge, or one that runs only on electricity?
I assume that the gas/electric fridge will allow operation for longer without driving the car to recharge the batteries. But will it not work as
well inside a hot car when the temperatures rise?
I am also considering a solar panel system, so maybe that can run the fridge in a similar way to the gas option, so it can run without mains power or the engine running for long periods of time.
Thanks,
Simon
Canberra.
Reply By: Motherhen - Tuesday, Nov 20, 2007 at 22:29
Hi Simon in Australia
Get a compressor type fridge (Engel Waeco or whatever). Personally, i will NEVER light a gas fridge in a camper or caravan (big bang paranoia). Compressor fridges are more efficient in hotter areas anyway.
Back in the tent days, the Engel ran from the cig plug when driving, and we gave it a run in the evening when the generator was running. This was adequate.
When we bought a small camper van, we threw out the defunct 3 way and bought an upright Engel caravan fridge (about 130 litre) - an excellent fridge. With a portable solar panel to put out to face the setting sun when we stopped to charge a deep cycle battery, we had adequate power.
We recently went
camping in our F250, with the same old solar panel mounted on the canopy roof, and it kept the battery
well charged all the time, running a 40 litre Engel and 12 v fluoro lights, even on a couple of dull days.
Go solar and forget the gas - that's my opinion anyway.
272847
Reply By: herkman - Wednesday, Nov 21, 2007 at 06:30
Good morning both of you, special wave to motherhen, trust
Bridgetown is as lovely as ever.
Simon the advice given to you by motherhen, is most valid and I believe very important.
When we purchased our last van, we allowed ourselves to be talked out of a 12 volt fridge, and I now regret it.
Running a 12 volt fridge on the go, can be achieved by using a switching device, which will allow the battery in the van to be charged whilst you are travelling. When stopped you can use a solar panel.
The problem with running a three way fridge, is the high current draw, I doubt if a solar panel will keep up with the 10 amp requirement.
In any case a 12 volt fridge/freezer will overcome the other problem of three way fridges, which is lack of space particularly in the freezer.
You will quickly pay for the extra cost of a better fridge, because you will be able to
shop less, particularly where local shops can be a tad expensive.
I would buy the biggest combination, that can be realistickly fitted into your unit.
Simon you are buying a good van, do not hold it back with second rate equipment, your wife will love you more for it.
Col
272873
Follow Up By: Motherhen - Wednesday, Nov 21, 2007 at 14:02
Hi Col
Glad to see you on the
forum again.
All good advice for Simon too.
Mh
536264
Reply By: Member - Mainey (wa) - Wednesday, Nov 21, 2007 at 11:49
Wonder what type of fridge they use in 5th wheelers, Winnebago's and various other large Motor-homes etc ??
272923
Reply By: Ralph C - Wednesday, Nov 21, 2007 at 15:58
Hi Simon,
For your application a 12 volt chest type fridge, eg Engel / Waeco. is the most compact energy efficient way to go. An upright fridge will take up much more space and lose most of it's cold air each time you open the door. It will therefore rely on the accuumlated cold of the fridge contents to give the appearance of staying cool.
A Three way gas fridge is definitely not suitable inside a vehicle and must never be run on gas whilst on the move. These types of fridges are best in a Caravan or Jayco style camper trailer where they run happily on 12 volt whilst driving and most efficiently on gas when stopped overnight.
Finally your wiring from the battery will neeed to be sufficiently thick to carry the current to any compressor fridge. The wiring to the cigarette lighter socket will work for a time but will become hot and may fail. Worse case scenario the wiring will catch alight.
Ralph
272960
