Plastic taste in water tanks
Submitted: Friday, Nov 23, 2007 at 17:49
Member - Cruiser (NSW)
Does anyone have a sure fire way of removing the plastic taste from the
water tanks in my caravan.
I have drained them and then flushed them (using food grade hoses) and the taste just wont go away.
Any advise appreciated.
Cruiser
Reply By: Tony MD - Friday, Nov 23, 2007 at 17:58
I found that lemon juice worked
well and is more cost effective than Scotch.
Cheers, Tony
273365
Reply By: Member - Tim - Stratford (VIC) - Friday, Nov 23, 2007 at 18:06
Cruiser,
We had the same problem - started to go off the lemon essence so we switched to vanilla - got sick of this too.
We always filled the camper
tank using food grade hose (blue stuff) but used nylex 'click' fittings to attach same to the hose and camper.
Plan C involved placing a
water filter inline in the fill hose - it is the large style with replaceable filters, approx 30x10cm in size.
Never had a problem since. I have a suspicion that the way I fill the camper in a closed environment (all click fittings) that the
water treatment chemicals don't have a chance to escape - the filter stops all this. we don't have to use anything at all to mask any 'bad tastes'
Tim
273366
Follow Up By: Member - Cruiser (NSW) - Friday, Nov 23, 2007 at 18:22
I use the food grade hoses (although
mine are white) but had not concidered using a filter. I have one but have never used it because we have always had good quality
water sources and it was intended to use it at some stage when the quality is a bit doddgy.
I will drain the tanks and flush them again on the weekend and then refill with the use of a filter and see what happens.
Maybe I can fit the filter under the kitchen, because after all, thats the source from where you notice the taste.
Cruiser
536690
Follow Up By: Member - Tim - Stratford (VIC) - Friday, Nov 23, 2007 at 18:32
Cruiser,
A mate with a
Kimberley Kamper also had this problem - he installed a small 'under sink' style filter (the type for
drinking water only taps) and has this plumbed into the kitchen sink tap.
His theory now is he can fill with 'suspect'
water and it should be ok as the filter should stop the critters coming out!
I'm not as confident, but with reasonable
water it will make it great.
Tim
536694
Reply By: Member - barry F (NSW) - Friday, Nov 23, 2007 at 18:25
Thats an interesting comment Cruiser. We have food grade hoses, but we notice if we fill the electric jug first thing of a morning, out tea or coffee has a plasticy taste. I've always put it down to the
water sitting in the hose overnight.
Our practise now if connected to caravan
park tap is to let a little bit of
water run first (waste) & then fill jug, end of problem.
We have never had the problem if using
water from the van
tank, so not able to help in that regard. Cheers
273367
Reply By: Notso - Friday, Nov 23, 2007 at 18:32
Another idea is to use a 500 gram packet of BiCard Soda and dissolve it in a bucket of
water then pour it into your
tank then fill it chockas and leave it sit overnight then drain and refill a few times.
Make sure you pump some of it through the lines as
273368
Follow Up By: Member - barry F (NSW) - Friday, Nov 23, 2007 at 19:26
The problem shouldnt realy exist (but I know it does ) We pay top dollars for food grade connection hoses & they seem to work, connect your van up with a cheap green garden variety hose & you will be convinced that its worth paying the extra dollars.
So why cant the same be expected from
water tanks fitted to vans that are going to be used for drinking. They should be injected moulded from food grade polethelene & not have the plastic taste. & they probabley are, the law would require it.
Maybe its the plumbing (plastic) between
tank & sink, or as another response mentioned, the grade of fittings used?
Sorry, no answers, just more questions!! cheers
536703
Follow Up By: 96 GXL 80 series - Friday, Nov 23, 2007 at 19:58
Do the same with Vinegar and warm
water.
do it a few times.
Then a good flush.
I wonder what they do to Condoms?
536713
Reply By: Steve Ellis - Friday, Nov 23, 2007 at 19:16
Gday Cruiser.
Notso is correct Bi-Carb is the solution and probably the cheapest solution. Also check that both the filler hose and delivery from the
tank are not clear plastic. That will taint the
water. Fill the
tank with food grade hose not garden hose at all times. I removed the hose that goes from the filler point to the
tank and replaced it with black plastic irrigation hose of the correct size. It needed a bend or two but did that with a heat gun and thick leather gloves. Put half a dozen turns of thread tape on the
tank inlet then the hose. Buy a decent hose clamp or even two and problem soved. That stuff is abit stiff and needs decent claps to compress it. The line from the
tank to the pump also needs to be
drinking water grade. I have also fitted a tee in the line with a little tap to drain the
tank when not in use. The local hardware should have the gear you need for that in the garden watering section. I actually removed the
tank and had a better go at cleaning it than if it had remained under the van. Plenty of dirt and muck on top and had the breather blocked. A Hose fitting so that you can fix the hose to the drain pipe also works and a quick fill and rinse out works wonders.
273376
Follow Up By: Member - Cruiser (NSW) - Friday, Nov 23, 2007 at 19:36
Steve,
The van is only 12 months old and I have checked, all the hoses both to and from the tanks are food grade.
Actually, all hoses throughout the van are food grade, even the one that goes to the
toilet for flushing.
I suppose I should have given more info on the original thread, but I filled the tanks once only using a common garden variety hose (was to lazy for my own good at the time) and since then, there has been this plastic taste despite immediately draining, flushing and refilling the
tank twice with the food grade hose I purchased (2 actually).
Sounds like the filter and bicarb are the go.
Thanks for the reply.
Cruiser
536705
Reply By: Cruiserman1961 (QLD) - Saturday, Nov 24, 2007 at 07:54
Hi Cruiser,
I use a cup of white vinegar when i come home from a trip. Let it sit for a couple of hrs and make sure you pump it through the plumbing. Repeat a couple of times. Fixed it for me for years. Some people recommend a teaspoon of chlorine but i am reluctant to try this.
Cheers, Udo
273435
Reply By: Member - Bentaxle - Saturday, Nov 24, 2007 at 09:00
Cruiser
Had a similar problem with a OL
water bladder, added 100mL of bleach, filled bladder and drained then rinsed out with Bi Carb solution a couple of times and have had no problem since. All fittings were food grade
Mike
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
273439
Reply By: Member Boroma 604 - Saturday, Nov 24, 2007 at 10:17
Gooday,
Have invested in a B.E.S.T. in lin
water filter, click in line when filling tanks, seems to work
Here is the blokes Free Phone No 1800-240-822 give him a caqll and ask him about it.
Have NO connection, seem very honest to me .
Boroma 604.
273450
Follow Up By: Member - Cruiser (NSW) - Saturday, Nov 24, 2007 at 10:22
Thanks for
the tip B 604.
I have decided to do the Bicard thing anyway (actually have just put it in and refilled
tank) as
well as an inline filter on the line to the sink.
I already have a filter to use on the fill line, but to date have never used it. Guess I will now.
Cruiser
536831
Reply By: Member - Cruiser (NSW) - Saturday, Nov 24, 2007 at 10:26
Thanks to everyone who has taken the time to offer advice on this matter.
As stated, I already have a
water filter to "click" into the fill hose, but have never used it.
With all the advice received, I have decided to use the existing filter in the future as
well as at the moment I am in the process of filling the tanks after having put in some bicard soda. I will leave this in overnight and then drain and flush in morning and then refill. In addition to this, I will source and fit a small inline filter on the hose from the
tank to the kitchen flick mixer.
All the help and advise is appreciated.
Cruiser
273453
Reply By: Member - Phil G (SA) - Saturday, Nov 24, 2007 at 11:38
Not all food grade hose is good.
I found the Nylex brand braided light blue hose to be the best.
A also found the Pope brand light blue, soft, smooth hose to be the worst.
Since changing every hose (incl fillers and breathers) to the Nylex
water hose I've had perfect
water from my
tank.
273461
Reply By: Axel [ the real one ] - Saturday, Nov 24, 2007 at 12:44
Go to your local home brew
shop and get some Metabisulphate , , failing that go to your local pub and ask for a little bit [cpl of hundred ml] of beer line cleaner , and run that thru all of your hoses /
tank , make sure you rinse
well = no bad smell or taste.
273466
Reply By: Richard D - Saturday, Nov 24, 2007 at 18:49
Hi Cruiser,
If you have a Whitworths outlet near you, grab a 200gm tub of '
Tank Cleen' . Cost is around $14.95.
Follow the instructions.
Works on plastic tanks very
I initially had the same problem with my plastic
tank in the camper trailer, and after using it , no problems.
As the other guys said , food grade hose is imperative as
i first used this product over two years ago now and still have no 'plastic' taste in the
water.
Good luck
Richard D.
273491
