Loose Wheel Bearings
Submitted: Sunday, Nov 25, 2007 at 10:28
Member - Hughesy (NSW)
Now I've changed a few wheel bearings in my time and never had any problems...until now.
What would cause the
wheels bearings on my cruiser to be coming loose?? I changed them about 6 months ago and nipped them up as I have always done (and yes I have the big "socket" that fits onto
the nut) and after my trip to Warraweena I knew they were loose because I had to pump the brakes up each time. So I did them up tight and low and behold when I checked them yesterday after 5000kms they were slightly loose again.
So I did them up TIGHT and we'll see what happens over the next couple of 1000 kms.
So what can cause the bearings to be continually coming loose??
I have used the locking ring and ensured the lock nut was tight. I always spin the wheel in both directions numerous times before "setting" the bearing load. Is there some other component that is worn allowing them to come loose???
Reply By: Member - Doug T (FNQ) - Sunday, Nov 25, 2007 at 10:36
Hughesy
After you have it all back together and nipprd up to where you think it will be OK get a length of 2" Gal pipe 1200mm long or a long handled heavy hammer and belt the crap out of the tyre 4 or 5 times , that will
seat the bearings in just a tad more , then re-Tighten again
273575
Follow Up By: Member - Hughesy (NSW) - Sunday, Nov 25, 2007 at 11:35
Thanks Doug.
Well after Warraweena the cruiser had done about 2000km and over some rough terrain so I would have thought that when I nipped them up after that trip that I wouldn't have any problems again.
Actually the only reason I checked the bearings this third time was because I was getting unusual wear on the front LH tyre and thought I'd eliminate the easier causes first.
536985
Reply By: Member - extfilm (NSW) - Sunday, Nov 25, 2007 at 11:02
Hughesy,
There is a possibility the cones were not seated all the way into the hub.
If they have been coming loose then I would suggest having a look at them and see if there is any pits or unusual wear.
The other possibility is too much grease was packed into the hub, therefore creating hydraulic lock effect. you may have thought the hub was home but in fact still had a mm or 2 before it sat on the spindle correctly. Easy to overlook.
I would be pulling it apart again, checking and repacking them.
273582
Follow Up By: Member - Hughesy (NSW) - Sunday, Nov 25, 2007 at 11:40
G'Day Peter, I'm beginning to thing along your lines too. I put the cones in with a hammer and large screwdriver and I look for the tell tale signs of grease being squirted out when the cones have hit home - but maybe they just weren't quiet home.
Yeah I go easy on the grease because most of it sits in the hub for 20000km doing nothing so I don't think it was hydraulic lock. I reckon the cones were'nt home.
Next time I'll take then to work and press them in with a hydraulic press.
How do you get the cones in and out at home Peter??
536986
Follow Up By: obee - Sunday, Nov 25, 2007 at 17:22
is it possible that the hardened wearing surface on the bearings has worn thru and they actually need replacing?
Owen
537014
Follow Up By: splits - Sunday, Nov 25, 2007 at 18:16
Hughesy
The usual way is to knock the cones in with a hammer and punch, not a screwdriver. The cones should also go into a clean hub with no grease in it. You add the grease after the cones are in.
You can easily tell when they are right in by the way the hammer feels. The moment the cone stops moving and is properly seated, you will notice a completely different and much more solid feel when the hammer hits the punch.
To remove them you just hit them with the same punch. Many hubs have a couple of little recesses cast into them where the cone seats. These are there so you can get the punch onto the cones easily. If they are not there then a few millimetres of the inside edge of the cone will be visable. You place the punch on whatever is visable, holding it on as much an angle as possible, then hit it.
The punch may slip a bit and the edge will become burred and need occassional dressing on a grinder but the cone will come out easily.
That method may sound a bit crude but I learnt it at work and TAFE and have been doing it for forty five years.
Brian
537026
Follow Up By: Member - Hughesy (NSW) - Sunday, Nov 25, 2007 at 20:08
G'Day Brian,
The grease I put in during assembly is only a very light smear to reduce friction and prevent rust if I get
water in the hubs.
Unfortunately my cruiser doesn't have those recesses you talk about. Getting the cones out is easy but to put them in I use a very large screwdriver because there is only about 1.5mm of cone face to hit against and the large blade helps spread that load. I might try it your way next time but I reckon I'll take em to work and press them in.
I'll see how they go over the next few 1000kms and if they loosen again I'll put a new set in and see what happens.
Thanks for the advice Brian - if you've been doing it for 45 years then I dare say you've done a squillion more than me. ;))
537054
Follow Up By: Member - extfilm (NSW) - Sunday, Nov 25, 2007 at 21:03
Thanks Brian,
You took the words from my mouth. And you learnt it 20 or so years earlier than I.
As far as I know it is still the prefered method and the rescesses are only there to knock the cones out. I always used a punch with no probs and in 5 years probably did 300 of them.
I always ground my punch to a flat point. Never would I use a screw driver. I would not even consider using a press.
537074
Follow Up By: Member - Hughesy (NSW) - Sunday, Nov 25, 2007 at 22:37
What's the problem with using a press? Aren't a lot of bearings/cones pressed in??
I'm only self taught so any extra knowledge would be good.....
537094
Follow Up By: splits - Sunday, Nov 25, 2007 at 23:10
I have no doubt the factory uses a press to fit them but no machanic that I have ever seen or worked with has used one. An ordinary punch about four or five millimetres in diameter will install them faster than you could set a press up.
If you have access to a press and you have a tool to push them in that does not jamb itself in the hub then go ahead, there is nothing wrong with it.
It is definately not necessary to use grease under the bearing, even a thin smear. The bearing is supposed to be a tight interference fit. At the same time though the grease would most likely not cause a problem with a bearing in good condition but if it ever dragged because of lack of grease in the rollers, deep pits in the case hardening etc, it might allow the cone to spin in the hub. I have never seen that happen so I don't know if it is possible or not but I do know you will not cause any problems if you install the cone dry and it will not get rust under it.
Brian
537098
Follow Up By: splits - Sunday, Nov 25, 2007 at 23:23
Just one more point Hughesy, the little recesses I was takling about are for removing the cone , not installing it. If they are not there then you must hold the punch on an angle across the opening in the hub to get a grip on the cone and reduce the chances of slipping. You move the punch back closer to verticle as the cone moves down.
Hold it straight up when installing the cone. You don't want to angle it and carve a grove down the side of the hub.
You will find a punch, either steel or brass with its end ground flat and square, will sit flat against the side of the hub much better than a screwdriver will.
Brian
537100
Follow Up By: Member - Hughesy (NSW) - Monday, Nov 26, 2007 at 01:25
Thanks Brian. I'll take all that on board. Might make it easier next time I have to do them.
537109
Follow Up By: Ray - Monday, Nov 26, 2007 at 08:27
Hi. I have put them in the freezer over night before fitting. Works quite
well but wear gloves when you do it
537123
