Troopy fuel question
Submitted: Sunday, Nov 25, 2007 at 12:49
ThreadID: 51956 Views:2756 Replies:5 FollowUps:6
Hi there,
Does an 1986 HJ75 2H Troopy have a fuel return line to the tanks?
Many thanks
Grant
Reply By: Member - Doug T (FNQ) - Sunday, Nov 25, 2007 at 13:47
All Diesels have a return to the main tank
AnswerID: 273602
Reply By: Rock Ape - Sunday, Nov 25, 2007 at 13:50
No, the 2h doesn't have a fuel return to the tanks.
AnswerID: 273604
Follow Up By: V8 Troopie - Sunday, Nov 25, 2007 at 20:49
I second that, always wondered why there was no return line but guess it had to do with the pintle injectors used on the 2H engine.
Klaus
FollowupID: 537068
Follow Up By: Member - Davoe (Yalgoo) - Monday, Nov 26, 2007 at 01:14
didnt believe it so I got the w shop manuel out
12ht has
........ 2h doesnt
1hz does
FollowupID: 537108
Reply By: Member - Sweeney (WA) - Sunday, Nov 25, 2007 at 15:33
HJ47's didn't have a return line. I have heard that the HJ60's did but not sure about the HJ75's (1984-89).
The HZJ75 (1990-98), HZJ80 and HZJ79's did have a fuel return line.
AnswerID: 273614
Follow Up By: Member - Kiwi Kia - Sunday, Nov 25, 2007 at 18:28
Hi Sweeney, (a bit off topic)
I have just had a look at your photos and note the one labelled 'Morning Glory'. Did this cloud roll through on the ground? I have seen them pass overhead at about 500 feet but did not know that they can occur at ground level. was there much noise and what speed was it traveling at ?
FollowupID: 537034
Follow Up By: Member - Sweeney (WA) - Sunday, Nov 25, 2007 at 21:30
What you see is not cloud, but a fine dust from memory. The photo is early morning shot of a fence line (two weeks later there was a fence), with slight cross wind blowing the fine dust giving the appearance of cloud/mist. I uploaded a another showing the fine dust of the area. Amazing place Australia is...
FollowupID: 537082
Reply By: Wayne (NSW) - Monday, Nov 26, 2007 at 07:31
Grant,
It all depends what type of fuel pump is used.
The 2H has a in-line pump with no return fuel line, and if it has a rotary pump it has a return line.
Wayne
AnswerID: 273704
Follow Up By: Member - Davoe (Yalgoo) - Monday, Nov 26, 2007 at 09:54
12ht has an inline and returns fuel. it is done from the injectors rather than the pump ala 1hz
FollowupID: 537129
Follow Up By: Member - Sweeney (WA) - Monday, Nov 26, 2007 at 11:09
All 2H's have a return line, but the HJ47's return the lift pump not to the tank. I heard that the HJ60's return to the fuel tank but I am not sure.
FollowupID: 537131
Reply By: grantb - Monday, Nov 26, 2007 at 08:34
Thanks for the info! This forum is awesome for getting quick answers.
I needed this to help convert to WVO
Thanks again!
Grant
AnswerID: 273705
