Driving Lights Feedback
Submitted: Sunday, Nov 25, 2007 at 12:57
Sonia
I need to know where I can compare different brands and types of the better quality
driving lights. I currently use both Ralley 2000 and Super Oscars. What else is available,or improvements on these. Thanks Ted.
Reply By: Outnabout David (SA) - Sunday, Nov 25, 2007 at 13:04
Opening up a can of worms there. Because it is like the best tyre, best fridge best car type question and is pureley subjective. I would suggest if you are happy with what you have then stick to them otherwise go for one of the recognised brands that such as Lightforce, Some of the IPF raqnge and the upper range Hella's.
Just consider how often you would actually get to use them and how far you really need o light the road up.
273599
Reply By: MEMBER - Darian (SA) - Sunday, Nov 25, 2007 at 17:42
Dealers all sell the "best value for money lights", :-o) ....... I have IPF Extremes at present (came with the new mota - they are 65W) but the all polymer base model Lightforce lights I did have (100W) may be the best value overall. Very light, easy to adjust, waterproof, allegedly unbreakable (not quite true, but tough) and can be focussed from spot to extra wide, they have a range of clip on transparent covers to choose from. Hard to beat IMO as a unit for the $375 odd a pair. They get a great rap here from forumites too, re service and backup.
273632
Reply By: The Rambler( W.A.) - Sunday, Nov 25, 2007 at 21:35
The Lightforce 240's seem to outperform the other known brands in all the tests Ihave read---also light and virtually unbreakable.Biggest problem is keeping them on the car without the "lowlife" removing them, as with most lights its two bolts to undo and there gone.
273675
Reply By: Member - Graham H (QLD) - Sunday, Nov 25, 2007 at 23:12
Reply By: Member - Barnesy (SA) - Monday, Nov 26, 2007 at 01:15
4wd monthly did a comparison a few years ago. The lightforce won if I remember correctly. Other than that I have used two different lightforce. 170 and 240 blitz.
The 170 were good and would do for most applications.
The 240 I upgraded to are fantastic and can see a long way down the road. As others have said they are light, strong and versatile.
Not to mention they were designed in SA by a country dentist and are made in
Adelaide. How many other lights can claim that?
Barnesy
273700
Reply By: arewelost - Tuesday, Nov 27, 2007 at 00:23
hi all
just for some useless information regarding the theft of
driving lights having had numerous sets removed i now drill and tap a thread and put in allen key grub screw into the thread below
the nut that locks them onto there mounting bracket/s this seems to have fixed the problem not many people carry allen keys with them
cheers steve
273824
