Twine / Glind water pressure
Submitted: Monday, Nov 26, 2007 at 10:56
ThreadID: 51980 Views:2505 Replies:3 FollowUps:0
If i get a 4wd shower installed in the troopy could i use the pump to wash the car as well as use for showering . Whats the pressure like . I have water restrictions and thought maybe i could do this .
Reply By: Member - Troll 81 (QLD) - Monday, Nov 26, 2007 at 11:16
won't be good enough if you want high pressure
AnswerID: 273722
Reply By: Moose - Monday, Nov 26, 2007 at 14:53
Define "wash".
OK for rinsing off. But couldn't use to blast mud off for example.
AnswerID: 273744
Reply By: MikeyS - Tuesday, Nov 27, 2007 at 13:48
As said above, you can certainly rinse the vehicle with the shower, but unless you get a higher pressure wash-down pump, which will probably blast the dirt off you, the normal shower pressure probably won't be enough to do the troopy. The flow rate of a wash-down pump will probably be a fair bit higher than a shower pump, so if you are drawing water from a limited supply (I use an onboard bladder)(on board the car, that is) a washdown pump is likely to empty the tank pretty quickly,whether showering or washing the vehicle. Check out a boating supplies shop like Whitworths if you want to source a washdown pump.
AnswerID: 273882
