Bribie Island info required
Submitted: Tuesday, Nov 27, 2007 at 19:11
Member - steve H (QLD)
Hi all
All my family is working this weekend so i am taking the opotunity to do the bolt. My question is that i wont be getting to the island until dark.I am not to keen on doing
the beach in the dark as i will be on my own. I have heard there is an inland track, if there is ,what is it like and is it ok to do at night.
Steve
Reply By: Member - Graham H (QLD) - Tuesday, Nov 27, 2007 at 19:31
I live there but havent done either. There is a
ranger station on the island that can provide you with information. You need a permit to do
the beach but not sure about the other. Its all in the National
park so you probably do and last I heard some of it was closed.
Ring 13 13 04 for
camping in National Parks or www.qld.gov.au/
camping
273930
Reply By: ExplorOz Team - Michelle - Tuesday, Nov 27, 2007 at 19:52
Steve - if you use the menu at the top of the site - click on Treks to check if we have trek notes for this region. A quick check through the Qld listing of treks show a trek note for Bribie Islands exists, so if you click that it will take you that page with all the information you should need.
This is the link:
Bribie Island Trek Note
I noticed that this one has not yet been converted to the new format, but the information should be correct. You can let us know your feedback when you get back perhaps?! :-) Enjoy
273933
Follow Up By: Member - steve H (QLD) - Tuesday, Nov 27, 2007 at 19:56
I have been told that
the beach has been washed away quite a bit and i am after some recent info.
Steve
537326
Follow Up By: ExplorOz Team - Michelle - Tuesday, Nov 27, 2007 at 19:56
ie. the map shows numerous inland tracks and their are bitumen roads on the islands.
537327
Follow Up By: ExplorOz Team - Michelle - Tuesday, Nov 27, 2007 at 19:58
The notes talk about the washed out section that is closed and signed but if this is more a more recent report that you know of, then best to give the local
ranger a call. Best of luck - would be terrible to come a croppa in the night on your own!
537329
Reply By: Redeye - Tuesday, Nov 27, 2007 at 20:18
Steve,
Have been up
the beach many times. If it is high tide and not raining when you arrive it will be very heavy going at the bottom of the island. You may even be in the surf near the
camp sites at the top.
The beach is usually good with very few ruts from creeks etc.
You will have to drive across the Island to the surf side on a main road. There is only one access to
the beach all others have been closed. Drive across the Island. Turn left when the road ends at the pub and continue until you come to a 4x4 only track a couple of Km from the pub.
Main advice is to call the
ranger before going as
the beach does vary. and check tides
BOM
Lovely island but take the insect repellent and enjoy.
Redeye
273940
Reply By: Andrew (Bris) - Wednesday, Nov 28, 2007 at 01:32
Haven't been there for a couple of months.
Beach conditions can change quickly.
Rangers will have more upto date information.
The new inland track from the Rangers Station past Poverty Point is real good to drive (or it was last time) and brings you out near
the beach camping area.
273999
Reply By: stevesub - Wednesday, Nov 28, 2007 at 08:26
I live on Bribie and do
the beach and inland track quite often.
2 weeks ago was the last time I went up
the beach and there is one of the lagoons that has broken through to the sea which means there is now a stream across
the beach. The
water is about 300mm deep where we went through but there is also a drop off where the
water has washed the sand away. This can be from 100mm to over 300mm depending where you meet it.
The inland track is very soft sand past Poverty Point and is
well sign posted in the daylight - at night time, you could get lost in the myriad of tracks that you are not allowed to go on - there are dozens of them and they only have very small
no entry signs. EPA will fine you if they find you on these tracks in the morning lost.
If you let your tyres down (25 psi in our Rangie) and have a high clearance vehicle, the sand should be no problem but I have seen low clearance 4WD's incl Suzukis getting towed because of the deep ruts in the sand past Poverty Point.
A permit is required and previous posts have covered that issue.
My suggestion is to
camp at Poverty Point
camp which is easy to find in the dark, then go up the inland track next day. A booking is reqd for Poverty Point - and don't forget the Mozzie repellent as the Mozzies are vicious this year on Bribie away from civilisation.
HAve fun on our great island
Stevesub
274012
Reply By: snow - Wednesday, Nov 28, 2007 at 11:14
Personally I wouldn't
hazard the trip at night without back up
274032
Reply By: Member - Wayne B (QLD) - Wednesday, Nov 28, 2007 at 16:01
Did it 2 weeks ago and I would suggest you go to Inskip instead, not much to do with so little beach
Wayne
274068
Wayne
274069
