91 troopy wobble
Submitted: Wednesday, Nov 28, 2007 at 18:46
darrell.QLD
front tyres have a '"wobble""at about 80 kph .
i replaced the front damper today and that helped a bit/but
i can still feel it.king pins? bearings??
Any advice would be app//can u tighten front bearings??????
thanks in advance''''''''..darrell
Reply By: Stu050 - Wednesday, Nov 28, 2007 at 19:09
Try rotating your tyres, front to rear, could be uneven wear.
274098
Reply By: disco driver - Wednesday, Nov 28, 2007 at 19:11
Darrell,
Check out the all the following:
All ball joints/steering knuckles.
Damper bushes
Spring shackle bushes, (front and rear of springs).
Steering Box adjustment.
Swivel housing bearings (would be kingpins in a 'normal' vehicle)
Wheel bearings must be tightened to specification.
(no more- no less)
Tyre/Rim assembly for balance (preferably dynamic balanced).
Any or all of these (in combination) can cause the symptoms you are experiencing.
Good Luck in sorting it.
Disco.
274099
Reply By: Member - Luke (SA) - Wednesday, Nov 28, 2007 at 19:51
I just replaced the tie rod ends on my Patrol, they were stuffed and that has fixed the wobble I had at 80-90k/ph
Cheers Luke
274105
Reply By: Eric Experience - Wednesday, Nov 28, 2007 at 21:50
Darrell.
Very common in that and later models, since the
wheels are sourced from outside a lot where not round. Just jack up the wheel about 2 mm from the ground and spin it by hand if it touches the ground at one point you have a crook wheel. Most 4x4 wreckers don't have any good
wheels left because of this problem. be persistent and you will find a good set,some car yards tart up vehicles by putting even worse after market
wheels on then but it does provide a source of genuine
wheels. Happy days Eric
274134
Reply By: Robnicko - Thursday, Nov 29, 2007 at 08:58
Darrell
check your tyres. could be that the rubber has hardened up. I had a similar problem on my 80 series adn ended upchanging the tyres(which were 5 1/2 years old anyway) and now it's very smooth and no hint of wobble.
Rob
274177
