Calling Doug SP7200 troubles
Submitted: Wednesday, Nov 28, 2007 at 21:08
ThreadID: 52075 Views:1808 Replies:2 FollowUps:1
Doug
I have recently got a SP7200 and also got city navigator Europe as I am about to go there for a short trip.
Been able to upload maps, waypoints, routes etc but the map does not display on the 7200 even though the map is enabled. The waypoints and routes all come up but not the map.
Any ideas?? I unlocked the map on the pc no problem and it all displays beautifully on the pc but not on the 7200.
Reply By: Member - Peter D M - Wednesday, Nov 28, 2007 at 21:31
hi alan
sympathise with your problem but have you tried contacting doug via a member message, a very good site feature and sure to get to him.
regards peter
AnswerID: 274132
Reply By: Member - Doug T (FNQ) - Wednesday, Nov 28, 2007 at 22:27
Just seen your post before retiring early for the night,
I have not had a play around with one of these but as with other units if you have 2 sets of maps somewhere in the MENU you should find a place where you can tick a little box , so you would untick the Australian maps and tick the European map .
Also in the Nuvi is a place where you can make it show least / More / and Most set it on most or best.
Depends on how you uploaded the maps too , you know if you add only a section of a map , when you upload that section it deletes all other maps on the GPS , you must upload everything you want on the GPS in one go , i.e on the PC Highlite all of CN8 , switch to the other mapping software and highlite the sections or all of that and then upload the lot .
Doug
AnswerID: 274139
Follow Up By: Member - Alan H (Narangba QLD - Thursday, Nov 29, 2007 at 07:42
Thanks Doug, I will try again
FollowupID: 537636
