Have you seen / got this fridge slide
Submitted: Friday, Nov 30, 2007 at 21:44
ThreadID: 52138 Views:6100 Replies:5 FollowUps:5
I noticed this in a recent 4x4 mag and it grabbed my attention. I was after a slide that dropped lower to allow better access into the fridge.
This seems to look the part and I will contact them next week as its seems they are a Brisbane firm.
What do you think of it or does anyone have one and what are they like? Leave the cost out of it for the moment.
Web site is www.platinumgear.com.au the site does not show bugger all guess its under construction. Or check out page 242 in 4x4 action mag.
Brian
Reply By: Member - GRANT HID(NSW) - Friday, Nov 30, 2007 at 21:57
Looks like a very useful system,your right it shows bugger all.
I wonder how the fridge goes back up.
Grant
AnswerID: 274457
Reply By: Sludgie - Friday, Nov 30, 2007 at 21:57
Gidday Brian,
I saw one of these at the 4wd show in Perth and was happy to fork out the $500.00 including postage to Perth.
I had been thinking of something along these lines but never did anything about it.My troopy has 300mm high _Affordable_Storage_Drawers.aspx and with a normal slide needed a ladder to reach the top. This new unit drops it about 250mm to a more usable height.
When you look at the system it is fairly simple but seemed to be effective in the demonstrations.If you have a ute with a tail gate the slide will only go as far as the tail gate.This unit I believe was designed by Shane of Michelle Sacs (hence the high price) , I should have mine in 2weeks time as there was a 1 month delay.
Sludgie
AnswerID: 274458
Reply By: Member - Brian H (QLD) - Friday, Nov 30, 2007 at 22:14
It maybe designed by Shane ...... I was not aware he was in Brisbane as that is the contact number I have.
I have a drop side ute as in my rig pic and as I see it it would drop quite low and be rather easy to access the inside of the fridge. A HUGE bonus for the wife.
How it comes back up I am hoping it is like a release clip and move via the struts (if that how it works).
I would be interested in what you think of it when you get yours.
Brian
AnswerID: 274461
Follow Up By: Member - Rob S (NSW) - Saturday, Dec 01, 2007 at 08:55
Michelle's Sac's moved to Yatala earlier in the year.
I only ever made one mistake
and that's when I thought I was wrong!
FollowupID: 538072
Follow Up By: Sludgie - Saturday, Dec 01, 2007 at 10:14
Gidday again Brian,
the drop sides on the ute should be fine,it was only on the tailgate that dropped to a horizontal position that restricted the slide.The unit has a locking pin/clip that allows the fridge to slide out and 2 struts to manage some of the weight on dropping and lifting.My wife is of a small stature and had no trouble lifting the full fridge back into position.The only thing that you may have to allow for is how far out the slide goes to miss the sidegate of the ute.Hope this info clears things up a bit.
Sludgie
FollowupID: 538082
Follow Up By: QLD Kev & Darkie - Saturday, Dec 01, 2007 at 10:18
Is there one for a bigger fridge. eg a 60L engel ??
Cheers Kev
Russell Coight:
FollowupID: 538084
Follow Up By: Sludgie - Saturday, Dec 01, 2007 at 11:15
I believe there are 2 sizes available,1 to suit a 60 litre.
Sludgie
FollowupID: 538091
Follow Up By: QLD Kev & Darkie - Saturday, Dec 01, 2007 at 11:18
Thanks,
I may have to investigate it and get one for my 60 litre Engel.
Cheers Kev
Russell Coight:
FollowupID: 538093
Reply By: pt_nomad - Saturday, Dec 01, 2007 at 05:48
Looks to me that it is a manual lift to return the fridge into its sliding position. I think the girlie in the picture would struggle with a full fridge.
Paul
AnswerID: 274480
Reply By: Member - Brian H (QLD) - Monday, Dec 03, 2007 at 23:53
Managed to chat with the owner of this slide and I am keen to check them out some more. One to suit my trailblazer will not be available till March (bugger).
Operation is via gas struts and I've been told a full 50 litre fridge (may have been 60 litre he said ) and is no effort at all, in fact he said only take a couple of fingers as the struts do all the work.
The slide drops down 300 mils which on my drop side ute will put it at an easy height. If my wife comes camping again THAT will be a must.
He indicated to watch the web site as its being updated when they get a chance.
Brian
AnswerID: 274881
