Turbo Whistle on 100Series TD auto
Submitted: Sunday, Dec 02, 2007 at 00:52
ThreadID: 52167 Views:5794 Replies:7 FollowUps:14
I did a search on this one but couldn't find any info
Just getting to know my car, only had it a few weeks, I find that the turbo whistle when spooling up is very audible(with window down)...no worries when cruising or anything but it gives me a feeling of boost being lost and a loss of power. That may not be the case, she's a heavy load to get moving.
Anyone notice this as much as me or am I just being 'anal'...could the loudish whistle be a sign of something?
Reply By: Member - Hughesy (NSW) - Sunday, Dec 02, 2007 at 01:19
All normal Andrew. I'd be worried if you couldn't hear it. I've just fitted an after market turbo to my 100series and I like nothing better than window down and raido off....listening to that sweet whistling noise. Enjoy it and don't worry about it!!!
AnswerID: 274619
Follow Up By: Member - Bucky (VIC) - Monday, Dec 03, 2007 at 04:18
Gotta agree with Hughesy there.
Nothing better than the sweet sound of a turbo doing its thing, except if you are in an old Acco Tipper.
Bucky
FollowupID: 538355
Reply By: Ray - Sunday, Dec 02, 2007 at 08:21
You should stand next to a Mirlees engine when it takes a load. The noise from to turbo is unbearable but nothing wrong
AnswerID: 274633
Follow Up By: furph - Monday, Dec 03, 2007 at 08:04
Ray.
Where and when did you hear that Mirlees engine under load?
In the 50's I worked in the sawmill at Licola (Vic.) which was powered by a staight 8 Blackstone/Mirlees 450kva set.
One of my jobs (mill maint.) was looking after that old girl, what a beautiful engine.
And the sound from the turbo as the load came on was quite something.
Also worked on a 5 cyl. Ruston, just a continual "clackety clack"
furph
FollowupID: 538360
Follow Up By: Ray - Monday, Dec 03, 2007 at 08:50
Hi furph,
I worked on Mirrlees KV16 majors at Kambalda in the early 60s and also Blackstones in Kalgoorlie and Norseman. Also a number of Rustons (G.E.C., English Electric) and of cause the old Bellis and Morcolms. We did find, although I did not work on them as they were redundant some old Thornicroft Vis-Vis engines. My worst experience with engines was a twin bank Blackstone in Kalgoorlie which threw its governor and took off. It later died of silicosis
FollowupID: 538368
Follow Up By: furph - Monday, Dec 03, 2007 at 15:58
Thanks Ray.
Bellis & Morcolm. Another memory for me. Some of the bush mills in E. Gippsland were steam operated and the B&M fully enclosed high speed double or triple exp. would have been the Rolls Royce of steam power. Whisper quiet too.
They would last forever, but boiler maintenance/water treatment was another matter!
cheers furph
FollowupID: 538433
Reply By: MEMBER - Darian (SA) - Sunday, Dec 02, 2007 at 08:55
Yep - I have the up/down turbo whistle too on the 05 GXL 100 - only noticeable with the window down.
AnswerID: 274637
Reply By: Member - Brian (Gold Coast) - Sunday, Dec 02, 2007 at 09:45
Stick a 3" exhaust on it and listen to the note then.......
Beautifuuuuuuuul!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
LOL.....
AnswerID: 274648
Follow Up By: stefan P (Penrith NSW) - Sunday, Dec 02, 2007 at 13:04
Yep I agree, I have a straight through exhaust on the patrol, Windows down, Cap on backwards, arm out the window. Turbo whistle heven!!!!! LOL
One of the joys of having the turbo :)
Cheers Stefan
FollowupID: 538280
Follow Up By: Member - Sam (NSW) - Monday, Dec 03, 2007 at 08:01
Its a note my 4.2TD Patrol shall be singing as of Thursday!!! And what a sweet song it will be!!!!
FollowupID: 538359
Reply By: jdbb - Sunday, Dec 02, 2007 at 20:37
I was wondering what that noise was - 1 less thing to worry about now.
AnswerID: 274700
Reply By: fisho64 - Monday, Dec 03, 2007 at 00:34
cant hear any turbo whistle on my 100 series? Is this the one you just bought?
Have a look around for a loose or missing fitting on the intake or intercooler (somewhere on the pressure side turbo to intake)
1HD-FTE dont normally make it (turbo whine)?
AnswerID: 274728
Follow Up By: Andrew(WA) - Monday, Dec 03, 2007 at 19:25
Fish..
Your the only one who says it's not normal....Hope something isn't wrong with yours LOL...
Reading the other replies seem to indicate this is a sound they all make!
FollowupID: 538487
Reply By: TD100 - Monday, Dec 03, 2007 at 19:19
Hi Andrew,
i have a 03 100 factory TD and she sings a beautiful song,standard it whistled under load with window down only,now it has 3"exhaust,D-tronic and increased boost and NOW she whistles!magic sound-just enjoy it cheers Paul
AnswerID: 274823
Follow Up By: Andrew(WA) - Monday, Dec 03, 2007 at 19:27
Thanks TD100
That 3'' exhaust you've got...did you do any other mods or just whack on the exhaust and go, apart from the Dtronic I mean.
And what diffences did the larger exhaust make?
FollowupID: 538488
Follow Up By: Andrew(WA) - Monday, Dec 03, 2007 at 19:28
That should read...what 'differences'
fingers move to fast for my head to keep up!
FollowupID: 538489
Follow Up By: TD100 - Monday, Dec 03, 2007 at 20:11
Andrew,
Initially i fitted the exhaust and found it spooled up quicker and had a noticable difference,then fitted the D-tronic,again another noticable difference better idle,less smoke,sharper throttle response.up the boost to 15 psi just rounded the package off nicely,chalk and cheese from std to modified.round town fuel economy remains same but far improved performance and also towing ease.can take off from lights on slight uphill or corner and spin front wheel(285/75/16 ATs)once boost kicks in(1500-1700 rpm)stoked with its performance now,drives heaps better.cheers Paul ps must watch that front diff now LOL
FollowupID: 538498
Follow Up By: Andrew(WA) - Monday, Dec 03, 2007 at 20:30
That sounds pretty good. I'm getting a Dtronic this week, might have it tomorrow!
How do you up the boost to 15 PSi as you mentioned, and what is it usually?
FollowupID: 538501
Follow Up By: TD100 - Monday, Dec 03, 2007 at 20:39
Fitted a variable boost controller(manual one)under dash.was 12.5 PSI before.apparently they have 16PSI cut outs fitted so i kept it under that.Paul
FollowupID: 538503
Follow Up By: Richard W (NSW) - Tuesday, Dec 04, 2007 at 07:39
My turbo also whistled noticeably before I added a 3" mandrel bent exhaust and D'tronic.
Does anyone with this configuration have the engine warning light go on momentarily when putting the boot in? The mechanic thought it might be over boosting and I've been thinking about a turbo boost and EGT gauge.
FollowupID: 538552
Follow Up By: TD100 - Tuesday, Dec 04, 2007 at 20:36
Richard,
when i poke mine in the guts flat foot it has a momentory dead spot then off she goes!doesnt matter if your cruisin or from standing start it does it.have never seen any lights come on.it is possible that it is over boosting and the cut out mom kicks in,brings light on then boost settles and it goes off.i have a boost gauge on mine and going to put an EGT on it too.but if it is only std i dont see it being that as stock boost is way below the cut off of 16 PSI.cheers Paul
FollowupID: 538677
