Gearbox & Transfer case Overhaul $$$$
Submitted: Sunday, Dec 02, 2007 at 14:00
ThreadID: 52173 Views:3439 Replies:7 FollowUps:4
Has anyone had a gearbox and transfer case overhauled for a 5 speed HJ60 or similar Toyota in the last 12 months or so and how much did it cost. I'm looking at a second hand HJ60 and the transfer is noisy in 4WD. I would do both boxes at the same time. So would like to know what I might be up for in the future.
Thanks everyone,
Joe.
Reply By: Chriscd - Sunday, Dec 02, 2007 at 14:16
Hi Joe -
Depending where you are
Try this guy in Brisbane
http://www.cobbysdiesel.com.au/
Seeya
C
AnswerID: 274674
Follow Up By: Chriscd - Sunday, Dec 02, 2007 at 14:25
Sori
Gympie
Seeya
C
FollowupID: 538287
Follow Up By: Member - Doug T (FNQ) - Sunday, Dec 02, 2007 at 14:45
Chriscd
........I think he might be on the other side of Australia
FollowupID: 538289
Follow Up By: Chriscd - Sunday, Dec 02, 2007 at 15:06
Hi Doug,
Realise that WA is opposed to Qld geographically, but WAS quoted $2500 plus $400.00 exchange return for a fully reconed box & transfer case into Darwin, again - on the other side of Australia.
Basically including freight component seems cheaper than your repair in the Isa.
Ta
C
FollowupID: 538291
Follow Up By: Member - Doug T (FNQ) - Sunday, Dec 02, 2007 at 18:15
Chriscd
My car was then a working car, time was the factor
FollowupID: 538311
Reply By: Member - Doug T (FNQ) - Sunday, Dec 02, 2007 at 14:54
Joe
I had my Troopcarrier Transfer done at Prosser Toyota , Gosnells at $1751
Change over Gearbox at Mt Isa about $3610
AnswerID: 274676
Reply By: Member - Shane D (QLD) - Sunday, Dec 02, 2007 at 17:43
This mob in Adelaide may be of help I've only read their Ads, dunno if any good
Shane
AnswerID: 274685
Reply By: PeterInSA - Sunday, Dec 02, 2007 at 18:00
2 years ago it cost me $3,500 in Adelaide on a HJ61 ie Turbo Diesel should be the same Box and Transfer case as the 60 series. Price depends on how many cogs and syncro gears they change the change. Included a heavy duty clutch as well.
AnswerID: 274686
Reply By: ross - Sunday, Dec 02, 2007 at 19:55
I had a H55f transmission and t/cse done. It was about $3000+ clutch kit$450 ,rear main$ 80 machine flywheel $55.
If you do the clutch and rear main seal its free labour,well sort of : )
I would also ask if the price guarantees a new 1st gear synchro and main shaft.
If they put a used one in they save $450 but rarely pass the saving on.
AnswerID: 274693
Reply By: 96 GXL 80 series - Monday, Dec 03, 2007 at 00:13
WA Joe,
why don't you try the mob in Bridgetown that do the engine conversions to the V8 Diesel.
They might have some laying around.
If not try a wrecker as they usually give 3mths guarantee on them.
Hope it helps.
AnswerID: 274726
Reply By: Shane (QLD) - Tuesday, Dec 04, 2007 at 11:29
If you do buy it & fix the box & tranny case make sure you put a by- pass hose in ! Hate to say it but by the time you do all this it will be worth more than the vehicle. I have a 60 Series T/ Diesel with 250,000k's & still on the origonal box, but that hose is manditory if you want longlivity.
AnswerID: 274936
