Prado Turbo Diesel common rail
Submitted: Monday, Dec 03, 2007 at 21:58
ThreadID: 52215 Views:7492 Replies:7 FollowUps:14
We currently have a 2004 Prado turbo diesel auto, pulling an 18'6 van weighing all up 2 ton odd and it seems to just cope. We are seriously considering getting a new van 21'.6 dirt road Trailstar Tare 2100 and when loaded will be between 2.4 and 2.7 tons.
We accept that there are limits that one can tow in so far as weight is concerned. We are hearing rave reports about the new Prado turbo diesel common rail with some 410 newton metres torque along with a far superior fuel consumption. Before we outlay sums, is there anyone out there that has a new Prado a/a and towing a van approaching our figures. Greatly appreciately any comments whatsoever from anyone on this dilemma.
Reply By: HGMonaro - Monday, Dec 03, 2007 at 22:23
Father in law upgraded from earlier diesel Prado (95 series but similar motor to yours) to a D4D and it does tow his van (around 2000kg) much easier than the old one however, D4D Prados still have a 2500kg towing limit, which wouldn't be enough for what you're looking at I believe.
AnswerID: 274865
Reply By: donk - Monday, Dec 03, 2007 at 22:24
I dont own a prado but i work for toyota dealers & the new common rail engine is way ahead of the old engine power wise
The problem i see is that the prado has a 2500 kg towing rating & a you will be either at or over that weight with a van that tares at 2100 kg
I would look at something with a higher rating
Regards Don
AnswerID: 274866
Reply By: Mick - Monday, Dec 03, 2007 at 23:18
I have a 2003 TD Prado and intend getting a new one but will wait for the new model. A new one now is the same model with an engine upgrade.
AnswerID: 274873
Reply By: Member - The Crow (QLD) - Tuesday, Dec 04, 2007 at 07:48
Have you thought of the 76 series V8 Diesel wagon it may not be as flash as a Prado but the GXL we have is great. It would suit your needs. We Tow a 21ft van and it does a great job. The fuel econ is great as well. It tows our van a lot better than the 05 3 Ltr Patrol we had and with better fuel consumption.
200 Series V8 Diesel
Thanks for the Rest Flying West and Flying Very Low along the track not coming back. The Crow
AnswerID: 274900
Follow Up By: Trevor R (QLD) - Tuesday, Dec 04, 2007 at 15:15
Is that right? You getting better economy out of your V8 than the 3lt Patrol? How much better?
Very interesting if you are.
Cheers Trevor.
FollowupID: 538612
Follow Up By: KSV. - Tuesday, Dec 04, 2007 at 15:48
4 pistons need to jump up and down twice faster then 8. While I cannot comment from personal experience between vehicles in question, I can compare V8 Commodor and 2.2 4 cylinders Camry we drove side by side from Melbourne to Alice Springs and back. Commodore actually consumed 1 liter less, would you believe it or not. Being sort of company vehicle (thus my company pays for petrol and service) it been never at mercy in regards to hard acceleration. I honestly believe that if I used it more gently, difference would be even bigger.
Serg
FollowupID: 538615
Follow Up By: Martyn (WA) - Tuesday, Dec 04, 2007 at 20:58
KSV,
Steady Neddy, if two engines are doing 3500 rpm the pistons are all moving at the same speed, with eight you have twice as many more to fill with vapour. I agree with what your saying about economy don't get me wrong but I don't believe it has got anything to do with one engines pistons going faster than anothers at the same RPM. My 4.2 turbo Patrol used to do the same litres / hundred up hill and down dale, my 3.0 Td is all over the place due to the computer dictating how much fuel the engine needs to maintain an efficient burn.Well that's my slant on things anyway. No offence meant at all if any is taken.
Keep the shiny side up
FollowupID: 538681
Follow Up By: Member - The Crow (QLD) - Wednesday, Dec 05, 2007 at 07:18
The Cruser has been gettin around 17.2 ltrs per 100ks while the patrol used upto 19 ltrs per 100ks towing. Thecruiser is gettin 11.2ltrs city and highway with out any load. The Patrol was around 11ltrs. I think thats pretty good for the cruiser when you compare the engine sizes. Mind you the cruiser only has 5000ks on it yet so I would expect it to get better.
FollowupID: 538716
Follow Up By: KSV. - Wednesday, Dec 05, 2007 at 09:25
Martyn,
My comment about “4 pistons twice faster” should not be interpreted exactly of course. Thing is that 4 cylinders engine usually sits on much higher RPM then 8 cylinders at the same speed. Although not necessarily twice, if course. On this example with Commodore vs Camry at 110 km/hr V8 was at 1200RPM while Camry’s one as 2200RPM. Obviously at the same RPM pistons jumps at the same rates, but thing is V8 needs far less RPM to achieve the same result.
Serg
FollowupID: 538736
Follow Up By: Member - Marilyn B (WA) - Wednesday, Dec 05, 2007 at 13:48
Do you know if you can get an auto in the Toyoto 76 4.5 litre series? Certainly looking at all options. ? price as well?
FollowupID: 538795
Follow Up By: KSV. - Wednesday, Dec 05, 2007 at 14:01
Nope, thankfully only manual. If you lock yourself on auto then go for LC200 – the same engine (even bi-turboed and tuned for more torque) and auto-only.
FollowupID: 538796
Reply By: Fazz - Tuesday, Dec 04, 2007 at 09:06
MarilynB,
you will find a lot of posts on your subject in the
www.pradopoint.com/
Web site
It should keep your interest for quite a while.
Fazz
AnswerID: 274908
Reply By: Gerhardp1 - Tuesday, Dec 04, 2007 at 10:29
If you want to save a huge amount of money, check this
Site Link
AnswerID: 274923
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 04, 2007 at 19:02
Maybe so but where do you put all the gear.
Our neighbours have just traded an almost new petrol vers of these as they found that it suffered badly from a lack of luggage space. They bought a 100 series cruiser and cant believe the difference.
Also found the Kia very thirsty towing a 2200kg van.
My 2005 TD Cruiser does about 6.3 km per litre towing a 2700kg van at maximum legal speed( and sometimes over)
Went from Brissy to Yamba and kept a check. Was reasonably happy with that as we were in a bit of a hurry and so were pushing it fairly hard. Expect to get better on a more leisurely trip
FollowupID: 538650
Follow Up By: Gerhardp1 - Tuesday, Dec 04, 2007 at 19:16
When travelling with a caravan, I would have thought the obvious place to put all the gear would be in the van not the car.
The link was expressly for the diesel, the petrol is like any other V6 (including the Toyota V6) in that it drinks like a sailor on shore leave after 6 months at sea. No-one should expect good economy in a V6 petrol in a heavy 4WD.
Comparing the Sorento to the 100 series is also a bit silly, they are completely different in price and size, and the Diesel Sorento will kill your 4.2 litre on economy. The 100 series will also tow more and be safer at the 2700kg limit of the Sorento, but it will also be heavier on all aspects of running cost including tyres, fuel, servicing.
Your neighbours obviously changed their requirements for vehicle luggage capacity sometime after buying the Sorento, as it's pretty obvious when you look at them that they aren't as big as a 100 series (or my Jackaroo for that matter, which can carry more than a 100 series).
FollowupID: 538652
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 04, 2007 at 20:13
Well I wouldnt put it all in the van as there are both weight and space restrictions.
Also some stuff is much easier carried and accessable from the back of a 4by. Dont fancy running back to the van to get a drink out of the Waeco.
I wasnt comparing the two. I was stating why the people changed and the car was only 4 months old. Admittedly a bad choice.
The original post was asking about towing a van of the same weight as mine.
I would therefore suggest a Cruiser or a big engined Patrol would be a safer tow vehicle than the Kia.
Also it is much less stressful on both the vehicle and the driver if you are towing in the mid range of capacity rather that at the extreme top end of it.
A bit like a fully loaded Mini trying to keep up with a V8 at 100kph. The Mini would be ringing its guts out while the V8 is just cruising. Which would last the longest???
To me reliability and comfort is a bit more important than outright economy.
Also in the remote chance I might need attention to the Cruiser, parts service and dealer availablility is a big factor as in this day and age of electronics etc, staying with the mainstream can be advantageous. Eg Neighbour dinged a mag wheel on the Kia Took 4 days to get one freighted out.
Plenty of Cruisers around to borrow or buy one off.
Its horses for courses and everyone is different but I had a 3.0 Patrol and bought a van which was 100kg too heavy so had to buy the Cruiser and I couldnt be happier.
Much better to ride in, goes better ( bigger motor) Not a lot heavier on fuel considering.
Servicing costs are similar within reason, most diesels have more expensive service costs so presumably the Kia is the same especially with a hitech common rail with much closer tolerances etc. Just my rant for the day
FollowupID: 538670
Follow Up By: Go Fishing - Tuesday, Dec 04, 2007 at 22:31
Had a Kia Sorrento myself, brand new.Suspension was shocking. Back end was skip on almost prefect roads. Installed OME suspension that fixed 80% of the problems.
Interior was nice, better than the Prado. Rear cargo was woeful in size. Pathetic to be honest. Roof rating no better, 45kg or something stupid like that.
13.5L / 100km city or country. Could not get under this figure no matter how lightly I was driving (no load and only 1 person). Journo's, who would drive normally, were getting 16 - 18L / 100km.
Tiptronic would somethimes have a heart attack up a steep hill. Dash would go blank, couldn't change gears manually or slot it into Auto. Had roll to the side of the road and switch the engine off the reset the auto. Scary stuff.
Sold it after the year and took a massive hit on resale value. No one wants them second hand. I added Stereo, Tints, Bull Bar, Suspension, Spotties, Rhinos about $4K all up. Lost $14K in 1 year. I know cars devalue as soon as they leave the dealer and lose the most in the 1st year but that is obscene. I was almost begging people to buy it.
Never again.
Have a new 07 Prado Auto GLX D4D. Room in the back is in another world. Accessories as long as your arm as well. Beautiful and economical.
FollowupID: 538696
Reply By: Member - Phil G (SA) - Tuesday, Dec 04, 2007 at 10:33
I'm no expert on towing, but have had friends who have rolled their Prado and caravan. I would have to agree with others that you need more towing capacity - say 3.5T that you get with the bigger LandCruiser. If you want auto again, you'd be after the 100 or 200series TD.
Out of interest, the 100series TD (1HD-FTE) with the 5 speed auto gives considerably better fuel consumption than your 1KZ-TE auto (11.0 vs 12.6 l/100k on the Fuel Consumption Combined ADR 81/01).
AnswerID: 274924
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 04, 2007 at 19:07
You can expect A 100 TD to use about 14-18 l/100k when towing, depending on the weight of the van, the load in the car and type of terrain.
Still better than a friend who has just been around the big block and at times was using up to 30l/100 k in a 4.5 petrol towing a 25 foot fully kitted Jayco. I suggested he get lighter boots. LOL
FollowupID: 538651
Follow Up By: Member - Marilyn B (WA) - Wednesday, Dec 05, 2007 at 13:45
Regarding your friends that turned the Prado and Caravan, can you tell us if it was because of the characteristics of the prado or simply was it drive error?
FollowupID: 538794
Follow Up By: Member - Phil G (SA) - Wednesday, Dec 05, 2007 at 18:09
Hi marilyn,
Hard to say, and usually theres more than one factor in why these things happen. It was an 18 foot caravan being towed by a 90series prado; may have been some crosswind; driver was competent and aged in his late 50's, staight section of road. He was at a loss to explain what happened, so i can't really comment further. But I'd guess that stability was an issue, and I'd guess that a bigger tow vehicle with a wider track may have been more forgiving.
FollowupID: 538837
