Site Search
Section Image
saving a route to file
Submitted: Tuesday, Dec 04, 2007 at 14:34
Member - George J (WA)
hi out there , i need to know how to save a route to file and be able to open up again i cant seem to open it up again , but i am able to open up my way points no problems with them opening up from there file
i go to the route editor but no route is stored on it
thanks you to any one ............george j wa
Advertisement
ThreadID: 52229 Replies: 2
Views: 379 FollowUps: 3
AnswerID: 274974   Submitted: Tuesday, Dec 04, 2007 at 14:45
The Explorer replied:
Hello - may help if you state what program you are using, OziExplorer (PC or CE), Garmin's Mapsource, Magellan's Mapsend, Trackranger...??
Carnabys Black Cockatoo
Click Image to Enlarge
“I was horror–struck to find my poor overseer lying on the ground, weltering in his blood and in the last agonies of death” E Eyre 29 April 1841
Reply 1 of 2
FollowupID: 538701   Submitted: Tuesday, Dec 04, 2007 at 22:08
Member - George J (WA) posted:
hi ,
thanks greg for you reply , i have ozi explorer
george.j wa
AnswerID: 275043   Submitted: Tuesday, Dec 04, 2007 at 22:47
GerryP replied:
Hi George,
When you have plotted all your waypoint, open the route editor and construct your route using the listed waypoints. After that, save save both the waypoints and the route files separately. Next time you want to use them, you then need to load the waypoints and route separately as well. Once loaded, you should find the route in the route editor.
Gerry
Reply 2 of 2
FollowupID: 538705   Submitted: Tuesday, Dec 04, 2007 at 22:55
The Explorer posted:
Yes - the Ozi help file (always a good reference) states
"Loading Routes from File
This is still causing me problems on how to code this properly.
At the moment you should make sure you load the waypoint file which you were using when you created the route. It is not possible to display a route unless the waypoints are loaded as well.
It is possible for the waypoint stored in the route not to agree with the waypoints loaded on the map if the waypoints have been modified since the route was created. This is corrected by pressing the ReLink button on the Route editor"
FollowUp 1 of 2
FollowupID: 538786   Submitted: Wednesday, Dec 05, 2007 at 11:53
thanks to greg and jerry for your help im only new at this so im still stepping my way throuth oz explorer seems quite complex at times
george.j wa
FollowUp 2 of 2
