Change from 6 stud to 5stud hubs 80 series
Submitted: Tuesday, Dec 04, 2007 at 16:40
hotfishez
Afternoon all, does anybody know if the 79 or 100 series 5 stud cruiser hubs fit onto an 80 series?
Reply By: Member - Graham H (QLD) - Tuesday, Dec 04, 2007 at 18:40
You get a better selection of rims with the 6 stud than the new ones so why bother
274998
Follow Up By: hotfishez - Wednesday, Dec 05, 2007 at 08:36
I run a 79 series as
well. wet season I change over to mud tyres due to the areas i travel to for work. I want to run one set of muddies i can swap between my 79 and 80.
538728
Reply By: Member - Shane D (QLD) - Wednesday, Dec 05, 2007 at 08:27
Nope!
many have tried to put 6 stud hubs on 78/79/100 series so they can have the
wheels they want, but find that the bearings totally different size.
Shane
275062
Follow Up By: hotfishez - Wednesday, Dec 05, 2007 at 08:38
I have been told the bearings are the same size. At this stage the only difference is the later model 100 series went to a bigger rear rotor.
I think next weekend I will try to swap the hubs over and see what happens.
Will keep you posted
538729
Reply By: Member - DOZER- Wednesday, Dec 05, 2007 at 17:38
My 80 runs 5 stud 100 series front diff and rear diff...they bolt straight in and have bigger brakes and lower ratio...so 35's run at the right spedo and gearing is back to std....if you put 100 series callipers on your 79, they have bigger pistons for better stopping
275158
