navara stx
Submitted: Tuesday, Dec 04, 2007 at 22:30
esttile
looking at buying navara stx. heard rear
suspension was weak & dust problems in tray area. we're doing the savana way from WA next year appreciate feedback
Reply By: Member - Mick O (VIC) - Tuesday, Dec 04, 2007 at 23:10
Owned the STR until last year. All similar utes (Navara/hilux etc) on the market have a
suspension set more for road "comfort" than off road stuff. I towed a camper trailer up the Strezlecki and
bore tracks, the Cordillo and then across the Donohue and Plenty with standard
suspension and factory tyres. No issues. If you're going to be doing major work (Canning type stuff) with a major load and/or towing then I'd consider a
suspension upgrade. I went for an Ironman kit (rear springs, 4 x gas shocks and front torsion bars) which was less than half the cost of other brands. Was very happy with the result. As to dust in the rear tray...do you have a canopy? If so and it has a sliding window at the front, open it half way. It'll go a long way towards presurising the rear and keeping the dust down. Also go to Clarke Rubber and get the self-adhesive neoprene foam tape about 6mm thick and 25mm wide. Fit it around the inside of the tailgate on
the tub edges so the tailgate presses against it when closing. You'll never stop all of the dust by virtue of the roads you're travelling but it certainly cuts it down.
Cheers. Mick
275038
Follow Up By: disco1942 - Wednesday, Dec 05, 2007 at 11:00
None of the utes have a dust resistant tail
gate. If they did - the rain
water would not drain out.
538759
Follow Up By: esttile - Wednesday, Dec 05, 2007 at 11:57
thanks Mick O will consider
suspension upgrade,& yes I do have a canopy [ so I'm not worring about the rain draining out PeterD but thanks anyway] & used the rubber seal on the Triton Ute with pretty good sucess on the Kalgoorlie/ Mt Augustus /
Gascoyne Junction run.also asking for any feedback on Savana Way road conditions. cheers & thanks Guys. esttile.
538774
Reply By: Kiwi & "Mahindra" - Wednesday, Dec 05, 2007 at 11:44
whats the difference between and st-x and an st-r....?? we bought the '06 st-r and its great....typical
suspension for utes though...all that crap that goes on under them is insane!!
have an upgrade or put airbags in the rear....
Laura
275089
Reply By: snow - Wednesday, Dec 05, 2007 at 13:15
The STX is the new model and quite different to the old STR bothe aesthetically and mechanically.
275101
Reply By: Wizard1 - Wednesday, Dec 05, 2007 at 14:43
A club member has a
old engine but near new standard ST-X. He struggles with most club trips because of his poor ground clearance and highway tyres. Even my Prado at standard height gets around without a drama.
He needs a
suspension lift just to make it a reasonable off roader.
And the Nissan front protection bar, what is with that bling?????
PS It is spelt Savannah.
275120
Follow Up By: esttile - Wednesday, Dec 05, 2007 at 15:40
thanks for the correction Wizard1, i'll use spell check next time
esttile.
538809
